Is there a way to record via MIDI with the LP via USB?
Everything Phatty.
keysareme
Post by keysareme » Sun Mar 09, 2008 5:59 pm
I purchased a M-Audio Uno Midi USB device, and was wondering if there is any way that I can use the device to record music to a midi file on my laptop via USB. Does that sound logical?
Assar
Re: Is there a way to record via MIDI with the LP via USB?
Post by Assar » Sun Mar 09, 2008 6:17 pm
You don't record music that way, you record midi data containing information about which key is pressed when and how hard (and a lot of other parameters). But you don't record the actual sound. To do that you need to connect to a line input on a sound card.
You can catch the midi data from you LP with a number of applications: MIDI-OX, Cubase, Reason etc.
Then you can use the midi data to re-play the music on any midi equiped instrument, hardware or software.
Little Phatty TE #1045 | Etherwave Theremin
Stockholm, Sweden - - - Listen at: assar.se
