Usually all my sequencers (from elektron or mfb) start the next sequence after the current sequence has completed all the steps, and of course the next sequence will start on time and from step 1, not randomly as i push a millisecond before or after that button ... with the moog sequencer you can't be sure if the next part will start on step 1 or will continue from the step you did not pushed EXACTLY in time .. let's say i have a 16 step sequence, i hit the next part of my song on step 16, the next sequence has 64 steps, i try to be in time, but the next sequence will start on step 16 or 1 .. depending on how fast i was
I use just a clock from the mfb tanzbar (i never had any problems giving clock from this device), and play the internal sequencer of the SUB37.
