Sub 37 sequencer cheat sheet
Here's a "cheat sheet" to make the operation of the sequencer easier.
Edit: an updated version is attached below
- Attachments
- CheatSheet.ZIP
- Sub 37 sequencer and modulation source/destination cheat sheet
- (114.37 KiB) Downloaded 542 times
- stiiiiiiive
Re: Sub 37 sequencer cheat sheet
Don't have any Sub37, but thanks for this initiative
Very nice, and well done! Thank you!
MBP 2012 | OS X 10.11.6 | Sub 37 #6768
well done sir! thanks!
Wow. So much thank you!
Source: am layout stuff
I know you put a lot of effort into making this, and I think it's really good. I have some comments, though:
There's a typo under Change Page: "KB OTAVE".
In the MOD SRC table, for the KB Track entry: doesn't middle C have MIDI note 60? I know there's disagreement on whether it is called C4 or C3, but I didn't think it changed what the MIDI note number was.
Some notes on the Mod Dst table:
- You propagate the error in the manual of LFO1/2 ranges: hi, med, lo. As far as I know, we get only Lo and Hi ranges.
- Ditto for leaving out Amp Env Delay.
- Missing "EG Times"; easy to do since it's in the text before the table; although it's not available for the Seq Mod Dst.
- ARP RUN is called ARP ON in the Editor and Hardware.
- I don't find OUT VOL in any destination list in the Editor (MOD Dest or Seq Mod Dest), nor on the hardware itself. However, there is a hardwired mod dst for VCA Level.
- You say "F.CUTOFF: Filter Cutoff Freq (only for seq mod!)" Technically, that's true - only SeqMod - but both Mods have dedicated mod amounts for the filter cutoff. I flip/flop on this issue myself... should the hardwired connections be included in a list of "everything you can do", or should they be left out because they're not in the list of selected parameters? I can't decide.
Would you want to list the standard LFO waveshapes along with the programmable sources, just for completeness?
Finally, somewhat off-issue: some mod dests aren't in Moog's list, although I really wish they were:
- LFO rates
- LFO waves
- Noise Level (maybe because it's already "hardwired" from the front panel, but still... can't modulate it from the sequencer mod dst)
- Osc Waves (ditto)
- Osc1/2 pitch (since there are dedicated knobs for them on Mod 1/2, but it's unavailable as a Seq Mod Dst)
- VCA level
I hope this doesn't come across as harsh or too critical. I certainly don't mean it that way.
- LFO rates
- LFO waves
- Osc Waves (ditto)
- VCA level
The modulation stuff was basically copied from the manual, apart from finding the differences between the main list and the one in the SEQUENCER >> MOD DST menu However I just tested now, and it's indeed centred around MIDI note 60.mikeh11 wrote:I know you put a lot of effort into making this, and I think it's really good. I have some comments, though:
It was called ARP RUN in Firmware 1.1, and was updated to ARP ON with firmware 1.2, so let's go with that.Some notes on the Mod Dst table:
Indeed. It's in the manual but not in the synth... Too bad that, as you say having VCA level as destination would be nice.- I don't find OUT VOL in any destination list in the Editor (MOD Dest or Seq Mod Dest), nor on the hardware itself. However, there is a hardwired mod dst for VCA Level.
Good point. However, I think this list should reflect the menus, not the hardwired sources/destinations since that would pull in several more entries that would need the difference explained, so I'll leave as it is for now. (I do wish that they would be selectable in the menus as well though, and that you could press MOD DEST button and grab the knobs in addition to cycling them with the MOD DST button, but it's not really important - I understand the rationale for doing it the way it is)- You say "F.CUTOFF: Filter Cutoff Freq (only for seq mod!)" Technically, that's true - only SeqMod - but both Mods have dedicated mod amounts for the filter cutoff. I flip/flop on this issue myself... should the hardwired connections be included in a list of "everything you can do", or should they be left out because they're not in the list of selected parameters? I can't decide.
To make it consistent with the menus-only listing, I think I'll leave that out in this document.Would you want to list the standard LFO waveshapes along with the programmable sources, just for completeness?
Not at all. On the contrary, thank you for the corrections, I'm all for quality in documentation (and everywhere else!)I hope this doesn't come across as harsh or too critical. I certainly don't mean it that way.
I have done the updates as we've now discussed, and I also included the MODWHEEL destination that was added in the SEQUENCER >> MOD DST menu for firmware 1.2. I will upload the new version in the first posting.
So everybody: there's a new version!
If Moog is interested, we now have some errata for the manual too:
- The LFO1RNGE and LFO2RNGE modulation destinations only have LOW and HIGH settings, not MED
- The KB TRACK modulation source is centred around MIDI note 60, not 48
- There is no OUT VOL modulation destination on the synth
Thank you!
OS X 10.5 Yosemite, 64 bit
Ableton Live 9
Sub 37 Tribute
Midas Venice F32
Ableton Live 9
Sub 37 Tribute
Midas Venice F32
Wow, thanks for this... Extremely handy and appreciated...
Fantastic, thank you!!
http://audiotecna.info
This is very nice and will be useful. Thank you for taking your time to compile this and share it with us. It is much appreciated.
