I've been trying to integrate the Sub 37 into my laptop DAW setup with varying degrees of success.
What I want to know and I don’t think this is possible but here goes:
I want to send midi clock from my DAW to the Sub 37 and then send that clock on through the Midi Out on Sub 37 to a separate Laptop. The problem is I don’t want to send any other midi data from the Sub 37 with the clock signal BUT I want send the Sub 37 Midi data back to my DAW through the USB at the same time.
So is it possible to use the Midi Out port as a Midi Thru whilst simultaneously sending all Sub 37 Midi Data out to my DAW via USB???
Any help would be appreciated
