Hi Moogers,
I recently bought a Slim Phatty. Everything workesd. Great sounds.till now: no more output... Tried everything: reset factory settings - play note: and "yes". Sounds on the speaker and in the headphone.... But nothing happens playing on my midi- device. Allthoung SP receives midi messages. What do I do wrong? Tnx for answering...
William
Then it was silent....
Re: Then it was silent....
I had similar problem once. It turned out that if SP is powered on with MIDI messages coming to its MIDI input it can lock out and produce no sound unless you trigger it with GATE/CV inputs. My sequencer was sending clock if not running, and that was the problem.
/Peter
/Peter
www.midisizer.com - home of MidiALF MIDI/CV step sequencer, MidiREX MIDI Looper and more synth DIY stuff...
It happened to me once, turned out I had left Local control OFF and I didn't remember...
http://audiotecna.info
Usefull tips.... Tnx. I took it a repairshop....next week it comes back.... We'll see..... Otherwise I'll use your advices......
Tnx again,
William
Tnx again,
William
- TheodoreLoughlin
What is the repairshop's opinion...did they guess which part of it went wrong?William Bovendeerd wrote:Usefull tips.... Tnx. I took it a repairshop....next week it comes back.... We'll see..... Otherwise I'll use your advices......
Tnx again,
William
