All the SP LIVE PERFORMERS !! issues-solutions
Regarding the moog is a "analog osc machine" that needs retuning, warming up, etc, those might be issues all live performers might be taking care about!!
--> Please, feel free to give suggestions and tricks or tell your experiences about playing shows and/or touring with the SP, this is my most worrying fact about the SP.
Re: All the SP LIVE PERFORMERS !! issues-solutions
1. Travel Case (original or custom made) - must have!
2. I always warm-up my Phatty at least 15 mins before my set, then turn off auto tuning to avoid '1st note delay' issue (if you don't touch keys ~15 seconds, phatty goes to auto-tuning mode, and then when you start playing, the first note you play sounds with some audible latency - the synth needs some time to revert from auto-tuning mode)
3. I use Perform Set menu to store your favourite presets
4. I use Pot Map feature to assign common contollers. For example, I assign Cutoff to Modulation knob, don't need to switch between cutoff and resonance in panel's Filter section.
Best regards, Ruslan Tagirov.
Toyz: MBPro+Live 9.x+LogicProX, Moog: LP StageII/Sub37/Grandmother/MF-104m/MG-105m, Nord: Stage2 SW73/ModularG2Engine, Roland: MC909/TR-8, Korg: MS-20, R-3, OTO: Bisquit/BIM, etc.
That's helpful. Thank you!
any suggestions for a nice travel case? people say that the lp travel case is way too big...tagirov wrote:1. Travel Case (original or custom made) - must have!
moog slim phatty, carbon copy mxr, electribe es-1, vermona drm-1, Doepfer A-125, A-106-5, A-143-9, MFOS 16-step sequencer, zoom h2
i've got the original ATA travel case, it's really HUGEbanyek wrote:any suggestions for a nice travel case? people say that the lp travel case is way too big...tagirov wrote:1. Travel Case (original or custom made) - must have!
i think of buying the soft LP gig bag or order some custom case.
What about a rack or mixer case?
http://www.sweetwater.com/store/detail/GR3S/
http://www.sweetwater.com/store/detail/SKB193U/
mixer case allows for an adjustable angle
http://www.sweetwater.com/store/detail/GMix12PU/
You need the ears though: http://www.sweetwater.com/store/detail/PhattyEars
thanks Sir, though i'm in Hungary, and this would only be the need for one gig - so i see no reason why to buy a rack case (yet). i'd rather stick to getting any safe gig bag for a nice price. maybe the LP gig bag would do it anyway, i don't know. it's only my supposition that once the LP is larger, its gig bag is no good for a SP in any way.Sir Nose wrote:What about a rack or mixer case?
Never thought of that, cheers!4. I use Pot Map feature to assign common contollers. For example, I assign Cutoff to Modulation knob, don't need to switch between cutoff and resonance in panel's Filter section.
I've never had a problem with lag with the auto-tune..maybe i just havent noticed it yet,
anyway I find by time I've turned it on, gone through soundcheck etc, at least 15min has passed so it's all warm and yummy.
Live, I use the LP with the Moog multi-pedal controlling the mod wheel via midi,
also the multi pedal sends a Sample and Hold signal to my ring mod frequency input, so with the mix at about 10'oclock on the ring mod there's a swampy S/H rhythm tickling the moog bass.
On top of that I have the LP controlling a Korg Ms2000R for a bit of polyphony in the background/top end, doing strings and other weird noises on top of the moog bass.
So at the end, I have 6 oscillators firing at once, 7 if you include the ring mod
If you have a midi controller make sure you have a decent power source.
My power cable on my controller came loose, only took half a second to get it back in but the SP was stuck ringing the same note and you'll have to cycle the power.
Can take a good few seconds to be back where you can start playing again.
I also like to keep a tuner plugged into the headphone out - you can just hit the output button to kill the main audio out and tweak the tuning between songs - this is especially good if you don't have enough time for it to fully warm up.
