Analog Mode question
- superd2112
The T-3 manual states that when in Master Mode/analog mode, the factory default setting is "Track". When I checked, mine was set to "pass-thru", and when I set it to track mode, the selected parameter's value will adjust up, but will not not adjust down below the preset's stored value - has anyone else experienced this? This only appears to be an issue when I'm in track mode - snap & pass-thru modes appear to be unaffected.
Update - this issue only appears to be occuring when, selecting the parameter to be adjusted, the control wheel is set below the preset's stored value - if the wheel happens to be above the preset's stored value, then the entire range of the parameter is available.
- superd2112
- superd2112
