Kind of a dumb (pre-purchase) questions here. Does the LP enumerate over USB as a MIDI device or some other kind of device? If it identifies as a MIDI device, can you then use the 5 pin DINs as MIDI I/O for the PC?
Also , can you do firmware updates (using SysEx or other) or USB or 5 pin DIN (MIDI)?
Little Phatty USB type?
Re: Little Phatty USB type?
It shows up as a USB Composite device. Firmware updates should be done with MIDI I/O for best reliability imo. I haven't tried FW updates with USB though, maybe Amos could shine some light on this?grantb5 wrote:Hi,
www.ctrlshft.com
Haven't tried it, but yes.grantb5 wrote:Cool. And when connected by USB, what of the 5 pin DIN MIDI connectors -- can you then use the 5 pin DINs as MIDI I/O for the PC? That is, does the LP act like a MIDI interface allowing other devices connected to the LP to connect to the PC (if you get my drift)?
