Tribute Upgrade
Everything Phatty.
lanxe
Post by lanxe » Thu Nov 13, 2008 3:03 pm
i havent opened my LPTE up yet, but i am assuming all the aforementioned chips are surface mount and not through hole (or better yet, socketed). so is the memory upgrade a chip upgrade or can we just swap out a board?
the reason i ask is: if i can help it, i would rather not trust my synth in the hands of UPS (or USPS or FedEX or anybody but me!). I have built quite a bit of modular synth stuff and have lots of diy experience.....but with through hole. just some surface mount stuff (that was messy). If the swap is not too bad, i would save the trip to moog.
but it looks like i will be sending it to them, with a prayer that the carrier doesnt kill my package.
last question:
if i send my synth to moog, can i keep the take off parts as spares?
Voltor07
Post by Voltor07 » Thu Nov 13, 2008 3:30 pm
lanxe wrote:i havent opened my LPTE up yet, but i am assuming all the aforementioned chips are surface mount and not through hole (or better yet, socketed). so is the memory upgrade a chip upgrade or can we just swap out a board?
last question:
Everything in the Little Phatty is surface mount. I had very good luck with using UPS shipping my LP in the road case sold on the website. Of course, I saved some money buying the case through Sam Ash. I would NOT attempt to switch ANYTHING out of the LP, no matter HOW experienced you are...unless you have all the tools Amos does. The ribbon cables that connect the two main boards are a real killer to get perfectly seated. I tried for 30 minutes and still couldn't get it right! Do your LP a favor. Send it to Asheville to get updated. :mrgreen:
haiku-ish
Post by haiku-ish » Thu Nov 13, 2008 3:55 pm
Voltor7, all of the LP owner don't live in the USA.
lanxe
Post by lanxe » Thu Nov 13, 2008 4:05 pm
i live in the US........so more than likely, i will just shut up and ship it in for this upgrade.
Still would like to know about the take off parts and if i can keep them (like the old memory chip and such). at the very least to say i still have the original TE!
Ryan
Assar
Post by Assar » Thu Nov 13, 2008 4:25 pm
lanxe wrote:Still would like to know about the take off parts and if i can keep them (like the old memory chip and such). at the very least to say i still have the original TE!
Actually, that's a good point, for some reason, don't know which, but it feels like a good idea ...
Little Phatty TE #1045 | Etherwave Theremin
Stockholm, Sweden - - - Listen at: assar.se
Voltor07
Post by Voltor07 » Thu Nov 13, 2008 6:36 pm
Yes, I am aware of that. But judging from the original message, I was able to figure out that lanxe does reside in the US. If you or another known international Mooger had asked for advise, I'd have said to go to a qualified local tech. Or more than likely, kept quiet and let Amos answer the post. :mrgreen: Cheers, haiku-ish!
haiku-ish
Post by haiku-ish » Fri Nov 14, 2008 7:37 am
is it ok to install the OS2 of the stage edition into an upgraded Tribute phatty ?
or there will be a dedicated OS2 phatty ?
dave500
No
Post by dave500 » Fri Nov 14, 2008 9:54 am
No you can not install the SE OS2 into your TE they are coding a new OS2 for the TE. :D
Model D, Little Phatty Tribute w/cv, The Rogue, MF-102, CP-251, Animoog and Filtatron
Voltor07
Re: No
Post by Voltor07 » Fri Nov 14, 2008 2:58 pm
dave500 wrote:No you can not install the SE OS2 into your TE they are coding a new OS2 for the TE. :D
But you CAN install TE OS2 in the upgraded TE. I imagine you could install the regular OS2 in an upgraded TE, but then you'd lose a bunch of stuff that only affects the TE. Like the AUTO feature. :mrgreen:
Steril707
Post by Steril707 » Sun Nov 16, 2008 12:11 pm
This sounds good, Amos...
Thanks a lot..
Looking forward to the new OS.
:D
Rudelius
Post by Rudelius » Mon Nov 17, 2008 4:39 am
[quote="Amos"]Hi gang,
Here's the latest news, so read carefully. :)
Also in the works:
For people who have a Tribute Edition and aren't getting the memory upgraded, for whatever reason, we are also going to release a new OS v1.04 for Tribute Edition only; This OS is basically the same as the current OS 1.03Tc, with the addition of a new "Auto" mode for the EGR Matrix.
At least for now I will not want to do the hardware upgrade to get to
version 2 unless I can find a *really* good tech to do that as I live
outside the USA, and I was wondering if the calibration issue (the high
pitched whine on some notes after doing the calibration procedure) will be
solved as well with v1.04?
Anyway, good to see that Moog is still trying to help people when a
product is not commercially interesting-, or not available, anymore.
Rudelius
haiku-ish
Post by haiku-ish » Mon Nov 17, 2008 1:57 pm
Ok my TE went to the tech this afternoon
for the Memory upgrade.
i've checked the Phatty with the upgrade 5 min ago !!
all went well, Image
the new memory is working good.
And now ? the O2 ? is the O2 SE is working for the now upgraded TE ?
hk.
dave500
OS V2.0
Post by dave500 » Mon Nov 17, 2008 7:06 pm
I don't think SE OS 2.0 will let you install to a TE. It should fail on the install. They are not the same synth even with a memory upgrade.
Voltor07
Re: OS V2.0
Post by Voltor07 » Mon Nov 17, 2008 7:11 pm
dave500 wrote:I don't think SE OS 2.0 will let you install to a TE. It should fail on the install. They are not the same synth even with a memory upgrade.
Oh yeah...good point! Too many synths that have similar names. :lol: Still, that kind of compatibility would be cool.
haiku-ish
Post by haiku-ish » Mon Nov 17, 2008 7:19 pm
Thank you Dave,
you're right, Amos confirmed this by email.
i'll wait untill the TE OS2 realease.
