104z a tonesucker
funkychorlton
104z a tonesucker
Post by funkychorlton » Tue Nov 11, 2008 2:07 pm
of all the foogers i find the 104z the least satisfactory sonically: and least benifits from overdriving the input. I would like to be able to leave it engaged all the time and a bring the delay in and out using the mix control but i find the unaffected signal to be heavily compromised - when I hit the footswitch to bypass the signal quite noticibly springs back to life. I can't find an input level which matched the bypassed level and which is also fairly clean
seem to me this pedal is only satisfactory of an fx bus, which i don't use live
anyone else found this?
f
Post by EricK » Tue Nov 11, 2008 2:11 pm
Is this a unity gain issue?
What is your input signal?
funkychorlton
Post by funkychorlton » Tue Nov 11, 2008 2:49 pm
my input signal is the mf102, somewhat overdriven
f
Bryan T
Post by Bryan T » Tue Nov 11, 2008 2:53 pm
funkychorlton wrote:my input signal is the mf102, somewhat overdriven
f
With that setup, I would probably run the 104Z Drive control all the way down and use the Output Level control to get the volume right.
Bryan
matt the fiddler
Post by matt the fiddler » Tue Nov 11, 2008 9:36 pm
fwiw i usually run mine in a parallel loop, with it 100% wet... that takes care of any problem I could have with it.
Matt
Electronic Violinist here
funkychorlton
Post by funkychorlton » Thu Nov 13, 2008 3:44 pm
using the input at zero and the output at almost 100% gave a much better signal than I was getting before - it still doesn't sound quite as sparkling as when the unit is bypassed, but its a lot better
thanks for the tip
f
Bryan T
Post by Bryan T » Thu Nov 13, 2008 6:22 pm
funkychorlton wrote:using the input at zero and the output at almost 100% gave a much better signal than I was getting before - it still doesn't sound quite as sparkling as when the unit is bypassed, but its a lot better
thanks for the tip
f
You're welcome! In my experience, proper gainstaging is important to get the most out of the Moog pedals, especially when working with a passive instrument (like a guitar) and an amp that expects to see an instrument level signal (like a guitar amp). The Low Pass FIlter, in particular, can be tough to dial in in a guitar rig.
Bryan
