Voyager Filter Glide soon to be fixed....
Rejoice!, I just received word from Linda that they are soon to release a modification to address the lack of filter glide.
......There is also a modification to the analog board to fix filter glide issues. If you are interested in that, please contact our Tech Support Department.
Best regards,
Linda
Linda Pritchard
Inside Sales
Moog Music Inc.
I have asked for the details from Tech Support. I will post the mod once I get it.
I can't wait.......
Stefan
Best regards,
Linda
Linda Pritchard
Inside Sales
Moog Music Inc.
I can't wait.......
Stefan
Re: Post Subject
Hello,Musashidan wrote:forgive my lack of knowledge, but what exactly is filter glide?
The glide function in the left-hand controller section routes the keyboard
cv thru a slew limiter to create a continuous change in pitch on the keyboard. On the Model D, the slew limiter was also assigned to the filter,
so that the pitch and filter functions would glide simultaneously.
Many (if not most) feel that the V'ger should be set up to most closely model the Mini D's functioning.
Although it may be implemented in a bare bones fashion, it will be interesting to see if the filter glide function is made switchable,
along with a choice of linear/exponential tracking modes.
Regards,
Lawrence
Type of Mod
The mod to add filter glide consists of lifting the leg of a resistor from the analog board and attaching a wire from the lifted end and routing the wire somewhere else on the analog board according to Moogmusic, however I have not yet received specifics. This means that unless you have Moogmusic do the mod (which BTW was originally proposed) you will most likely void the warranty. When the details are released do the mod at your own risk!! [There ends my disclaimer]
Therefore the glide characteristics of the filter will mirror the Pitch CV glide. So the implementation should be similiar to the model D.
Stefan
Stefan
I don't know who you talked to, but I twisted their arm and helped them design that filter glide fix back in 2003 when I brought my Voyager down there for a tune up. And the fix is indeed as bosonob describes. And no I can't share the details because of warranty issues. And yes the filter glide fix sounds great.
Re: Post Subject
Purusha wrote:Is the glide mod really necessary though, and would it affect any patches set up for the system as-is?
Hello,
The glide mod gives the Vger a character a bit closer to the Minimoog D.
Also, it does affect all patches that currently have the glide function selected. You can check out the difference if you have a VX/CP-251 combo.
The difference is enough that any patches that use just oscillator slewing would need to be re-programmed slightly (filter freq and kb tracking), because the addition of slewed votage to the filter makes them sound noticeably different.
Glide with and without slewing to filter are both useful in that if you have the Vger set up for simulations of Moog and non-Moog synths that use pitch slewing, but w/o filter glide, being able to disengage the filter glide keeps them authentic.
One possible solution would be to make the function selectable in the software, so that the function's status can be recalled with the patch.
Its not a complicated matter to make it switchable from the glide selector
switch, but having it selectable as a programmable function from the
parameter menu would be a little more elegant.
By having the filter glide function selectable from software (w/no filter glide as the default state), any patches w/pitch slewing previously programmed on Vger will sound the same and not require re-tweaking, and all new patches in which the user wants a character closer to the model D can have the function activated fron the parameter menu.
Rudi, I know things are busy, with the LP release, but how much trouble would this be to implement in the software?
Regards,
Lawrence
Re: Post Subject
Software selection is not possible as the keyboard CV to the filter comes from the same slew generator used for oscillator keyboard CV.LWG wrote: One possible solution would be to make the function selectable in the software, so that the function's status can be recalled with the patch.
Re: Post Subject
MC wrote:.... the keyboard CV to the filter comes from the same slew generator used for oscillator keyboard CV.
Hello,
Correct, but I'm not talking about creating a software-based slew function here. The glide rate and on/off state are already saved in patch memory.
If you wanted all three states, i.e. glide off, just oscillator glide on (as it is now), and osc glide w/filter glide, you'd normally have to change the
rocker to a three position switch to accomodate the third state. I'm simply referring to having the filter glide turned on/off from the menu,
instead of having to swap the glide switch to one that has a third position.
This would provide selection of the new filter glide state, plus all patches already created for Vger, using just oscillator glide, would remain unaffected.
Also, what is the cutoff point (serial number) for SE's that have only two keyboard cables?
Regards,
Lawrence
