so many choices...
so many choices...
Well, I am about to go in for the MuRF 105.
As you know, there a many accessories, e.g.: the Expression Pedal, the Tap Tempo Pedal, the Female/Male Step Adaptor. The MuRF by itself is expensive and these components combined add another ~$100
Based on those who have had some time with their MuRF, I am curious based on your own applications what, if any, of the above components are "must haves"
Lengai:
Thanks for the input.
Yes, leaning towards your reco given that I have a Machinedrum that I hope to use to modify the tempo via sending audio pulses. Not sure how well it will work, but I will find out on Friday when it arrives.
The notion of using the Tap Tempo Pedal and the male/female adapter thing for manually stepping through patterns is somewhat intriguing, but I need to get my head around it a bit more to fully appreciate the benefit...
- analoghaze
Does the MD have 6 aggignable outs?(not sure the specs)
If you can send a signal to say output 5 going into the MuRF, and use stereo outs of the MuRF, it will sound amazing.
I would have totally different effects on each output.
The MuRF will blow you away.
Well, thanks to Amos in technical support (and you folks) I am on my way to sonic heaven.
I am using the step adapter and sending click tracks from my Machinedrum to create some very cool sequence progressions. This opens up a nice spectrum of possibilities way beyond just using the Rate knob to step through the selected Animations.
Man, I love this thing with my guitar and it is a real stand out on my board that has some very nice pedals, e.g., Echoczar, Red Witch Moon Phaser, Teese RMC 3, DLS Chorus Vib, etc.
- analoghaze
Jeff:
Thanks. Yes, Ed does great work. I have his Echoczar and have been saving up for an Angel Baby and is new VFM pedal.
I may go for his Ernie Ball mod if I am not able to find someone who has an extra 100k linear pot that I can install in a EB volume pedal I already own.
The folks over at HugeRacks just teamed up and made a bulk purchase from Tocos (where they manufacture the correct pots for the EB mod) but I missed it...
