Duration of time it takes to do repairs
didlisquat
Post by didlisquat » Mon Mar 23, 2015 9:24 pm
I was wondering if anyone has had to send a product to Moog for repairs
If so, how long does it usually take to get it back?
thealien666
Re: Duration of time it takes to do repairs
Post by thealien666 » Mon Mar 23, 2015 10:34 pm
It all depends on what they have to do to perform the repairs. If it's a simple thing, it could be quick. But if it's a major issue, it could take longer I suppose.
torinkrell
Post by torinkrell » Tue Mar 24, 2015 12:23 am
If time is an issue and if you are hesitant to ship your precious Moog, finding a trustable local repair facility that you can build a connection with could be a real asset. For many years I would keep a backup of each my main synths knowing that repair work was usually unreliable and take a lot of time. Now I have a local repair shop I can go to that does good work where the owner knows me.
Akai AX-80
Korg Polysix
Roland Juno 60
Moog The Source
Yamaha e1010 BBD
Moog Parametric EQ
Sequential Prophet Pro~One
Altec AS-1600 audio oscillator (1947)
Moog Music Minimoog Model D (1973)
DeckardTrinity
Post by DeckardTrinity » Tue Mar 24, 2015 3:09 pm
You can contact them to ask about the length of the queue... for me last October it was about a month to repair one of the mod busses on my Voyager XL. The good thing is that I only needed to send in the analog board from the back of the XL, which was fairly easy to remove.
Also you can pay $50 (again double check with Moog for the exact price) to be moved to the front of the queue, if it is urgent.
torinkrell
Post by torinkrell » Tue Mar 24, 2015 4:54 pm
Didlisquat makes good points. I would also ad that if most of your synth still works or you have backup gear, you may time repairs for when Moog or your local synth repair specialist has a shorter cue.
Akai AX-80
Korg Polysix
Roland Juno 60
Moog The Source
Yamaha e1010 BBD
Moog Parametric EQ
didlisquat
Post by didlisquat » Mon May 04, 2015 3:23 pm
This is good to know. I'll have to do that next time. Over two and a half months and still waiting to see my fooger again.
