I was wondering if anyone has had to send a product to Moog for repairs
If so, how long does it usually take to get it back?
Duration of time it takes to do repairs
- thealien666
Re: Duration of time it takes to do repairs
It all depends on what they have to do to perform the repairs. If it's a simple thing, it could be quick. But if it's a major issue, it could take longer I suppose.
- torinkrell
If time is an issue and if you are hesitant to ship your precious Moog, finding a trustable local repair facility that you can build a connection with could be a real asset. For many years I would keep a backup of each my main synths knowing that repair work was usually unreliable and take a lot of time. Now I have a local repair shop I can go to that does good work where the owner knows me.
Akai AX-80
Korg Polysix
Roland Juno 60
Moog The Source
Yamaha e1010 BBD
Moog Parametric EQ
Sequential Prophet Pro~One
Altec AS-1600 audio oscillator (1947)
Moog Music Minimoog Model D (1973)
Korg Polysix
Roland Juno 60
Moog The Source
Yamaha e1010 BBD
Moog Parametric EQ
You can contact them to ask about the length of the queue... for me last October it was about a month to repair one of the mod busses on my Voyager XL. The good thing is that I only needed to send in the analog board from the back of the XL, which was fairly easy to remove.
Also you can pay $50 (again double check with Moog for the exact price) to be moved to the front of the queue, if it is urgent.
- torinkrell
Didlisquat makes good points. I would also ad that if most of your synth still works or you have backup gear, you may time repairs for when Moog or your local synth repair specialist has a shorter cue.
Akai AX-80
Korg Polysix
Roland Juno 60
Moog The Source
Yamaha e1010 BBD
Moog Parametric EQ
Korg Polysix
Roland Juno 60
Moog The Source
Yamaha e1010 BBD
Moog Parametric EQ
This is good to know. I'll have to do that next time. Over two and a half months and still waiting to see my fooger again.DeckardTrinity wrote:
