v1.0.4
Re: v1.0.4
After the 1.04 Update the midi-crashes all went gone, i thought...
But yesterday, after one hour, without doing anything with the Sub37, it was just simply switched on, suddenly Cubase freezes.
After i switched off the Sub37, everything was ok again...
Re: v1.0.4
v1.0.4 not available anymore from the s37 dl page. what happened?
[edit:] hm, but the direct dl link from the email announcing the update still works.
Re: v1.0.4
I'm not seeing 1.0.4 on the moog site, do you have a link? Also instructions for upgrading?
Re: v1.0.4
Hello Rufus,
Regards
Heiko
You can not hear it? Better you play different notes, not just one. Then it's easy to hear the frequencies that doesn't change their pitch, no matter what note is played on the keyboard ...Rufus the Dog wrote:This is several seconds of a single note using 'Latch On' for your listening pleasure.
https://dl.dropboxusercontent.com/u/48045856/OSc1.wav
Regards
Heiko
My current Moogs: Sub 37
My former Moogs: Minimoog Model D, heavily selfmodified Prodigy, Satellite, Etherwave Theremin
- Rufus the Dog
Re: v1.0.4
I'll give it another go Heiko - I did play several notes when I was listening I just recorded one. I can see it in the FFT but cannot hear it. It could just be my monitoring situations.. Sennheiser headphones but not particularly expensive ones so they may just be attenuating the low frequencies too much especially as the 80Hz is already >60dB down
R.
R.
Re: v1.0.4
It's strange...I saw the download link for OS 1.0.4. in the morning but didn't get a chance to download it and when I tried to download it later in the day it was gone!?
Would you mind sharing the direct link for OS 1.0.4.?
bartleby wrote:v1.0.4 not available anymore from the s37 dl page. what happened?
- Rufus the Dog
Re: v1.0.4
Try this http://moogmusic.us2.list-manage.com/tr ... c3c7942f2cbomarm wrote:It's strange...I saw the download link for OS 1.0.4. in the morning but didn't get a chance to download it and when I tried to download it later in the day it was gone!?
R.
Re: v1.0.4
Hi Rufus,Rufus the Dog wrote:I'll give it another go Heiko - I did play several notes when I was listening I just recorded one. I can see it in the FFT but cannot hear it. It could just be my monitoring situations.. Sennheiser headphones but not particularly expensive ones so they may just be attenuating the low frequencies too much especially as the 80Hz is already >60dB down
R.
maybe you could try this new one : https://www.dropbox.com/s/ai4mf7fq7kybw ... 1.syx?dl=0
I've saved with the "buffer send" command but if it doesn't work, try this one (saved as "preset send") : https://www.dropbox.com/s/dqb91eo905v9d ... 2.syx?dl=0
Please play the highest octave and let us know what u think (for me it's still there)
MOOG Memorymoog+, Sub 37, CP251, ROLAND SH-1, SH-2, SH-7, SH101, Juno 60, SVC350, TR808, SCI Prophet 5 Rev.3.1, KORG Mono/poly, KR55, OBERHEIM SEM, WALDORF Microwave 1, DSI Prophet 08 Desktop PE, BOSS DR-55, BassBot TT303, AKAI MPC1000 JJOS2XL.
- Rufus the Dog
Re: v1.0.4
Yes! Very faint but definitely there. Sennheiser HD 477 then HD 202 headphones plugged directly into Sub37's headphone socket. Volume to max. When I get a chance I will crank up my Peavey KB3 and will probably be able to hear it more clearly.gencomprodukts wrote:Hi Rufus,Rufus the Dog wrote:I'll give it another go Heiko - I did play several notes when I was listening I just recorded one. I can see it in the FFT but cannot hear it. It could just be my monitoring situations.. Sennheiser headphones but not particularly expensive ones so they may just be attenuating the low frequencies too much especially as the 80Hz is already >60dB down
R.
R.
Re: v1.0.4
Ah, cool mateRufus the Dog wrote:Yes! Very faint but definitely there. Sennheiser HD 477 then HD 202 headphones plugged directly into Sub37's headphone socket. Volume to max. When I get a chance I will crank up my Peavey KB3 and will probably be able to hear it more clearly.gencomprodukts wrote:Hi Rufus,Rufus the Dog wrote:I'll give it another go Heiko - I did play several notes when I was listening I just recorded one. I can see it in the FFT but cannot hear it. It could just be my monitoring situations.. Sennheiser headphones but not particularly expensive ones so they may just be attenuating the low frequencies too much especially as the 80Hz is already >60dB down
R.
R.
- BrufordRules
Re: v1.0.4
Does anybody know why the firmware 1.0.4 was removed from download section? Did they found a major bug or something?
Cheers
Cheers
Re: v1.0.4
Thank you for the link!Rufus the Dog wrote:Try this http://moogmusic.us2.list-manage.com/tr ... c3c7942f2cbomarm wrote:It's strange...I saw the download link for OS 1.0.4. in the morning but didn't get a chance to download it and when I tried to download it later in the day it was gone!?
R.
Re: v1.0.4
bomarm wrote:Thank you for the link!Rufus the Dog wrote:Try this http://moogmusic.us2.list-manage.com/tr ... c3c7942f2cbomarm wrote:It's strange...I saw the download link for OS 1.0.4. in the morning but didn't get a chance to download it and when I tried to download it later in the day it was gone!?
R.
If it's removed it's probably for a reason. I wouldn't update until there's info on why it was removed.
- Rufus the Dog
Re: v1.0.4
You have a fair point but it hasn't broken my Sub37, as far as I can tell, and V1.03 is available to revert if requiredJazzMasta wrote:bomarm wrote:Thank you for the link!Rufus the Dog wrote:Try this http://moogmusic.us2.list-manage.com/tr ... c3c7942f2cbomarm wrote:It's strange...I saw the download link for OS 1.0.4. in the morning but didn't get a chance to download it and when I tried to download it later in the day it was gone!?
R.
R.
- BrufordRules
Re: v1.0.4
They have uploaded the firmware 1.0.4 again but I won't be able to try it until the weekend.
Any issues with this one?
