v1.0.4
Re: v1.0.4
I´m still having trouble with the arpeggiator. Its RATE is not ranging from2 to 280 bpm. Sometimes you can only sweep the higher range but most of the time you can´t make it go fast enough. Is there a high/low setting I´m missing or?
If latched I also get hanging notes when switching preset.
- _DemonDan_
Re: v1.0.4
Hi XAXAU,XAXAU wrote:I´m still having trouble with the arpeggiator. Its RATE is not ranging from2 to 280 bpm. Sometimes you can only sweep the higher range but most of the time you can´t make it go fast enough. Is there a high/low setting I´m missing or?
Don't forget that you have tremendous control over what unit of the beat is used in the Arpeggiator (per Preset).
It's in the ARPEGGIATOR Sub Menu of the PRESET EDIT Mode.
_
_DemonDan_
_
Re: v1.0.4
Also, do you have something coming into your MIDI IN? It could affect the seeming range of the pot, when it is actually (maybe) setting the division of an external clock...
? maybe ?
? maybe ?
- Rufus the Dog
Re: v1.0.4
It looks pretty clean to me - best I have seen it!mmarsh100 wrote:Hey All -
Just got the notice for the new firmware update. I looked at the notes and there is no mention of the "buzz sound" fix. Is this in there?
Thanks,
Mike
R.
Re: v1.0.4
Awesome! I wonder why it was not mentioned in the release notes?
Re: v1.0.4
Rufus the Dog wrote:It looks pretty clean to me - best I have seen it!mmarsh100 wrote:Hey All -
Thanks,
Mike
R.
Well, by ears it's still there though significantly reduced
MOOG Memorymoog+, Sub 37, CP251, ROLAND SH-1, SH-2, SH-7, SH101, Juno 60, SVC350, TR808, SCI Prophet 5 Rev.3.1, KORG Mono/poly, KR55, OBERHEIM SEM, WALDORF Microwave 1, DSI Prophet 08 Desktop PE, BOSS DR-55, BassBot TT303, AKAI MPC1000 JJOS2XL.
Re: v1.0.4
too embarrassing, perhaps?mmarsh100 wrote:I wonder why it was not mentioned in the release notes?
Re: v1.0.4
sorry
Re: v1.0.4
Rufus the Dog wrote:You have magic ears
R.
Re: v1.0.4
Aha!_DemonDan_ wrote:Hi XAXAU,XAXAU wrote:I´m still having trouble with the arpeggiator. Its RATE is not ranging from2 to 280 bpm. Sometimes you can only sweep the higher range but most of the time you can´t make it go fast enough. Is there a high/low setting I´m missing or?
Re: v1.0.4
R.
Last edited by gencomprodukts on Tue Oct 21, 2014 4:13 pm, edited 1 time in total.
Re: v1.0.4
gencomprodukts wrote:Rufus, try one of my "Model D" soft lead sounds and let me know if you do hear something :Rufus the Dog wrote:You have magic ears
R.
https://www.dropbox.com/s/yjr63cdac16n4 ... d.syx?dl=0
I do (check with the last octave of the keyboard)
Re: v1.0.4
it may be hard to believe but I actually forgot about the noise fix when I was writing the release notesmmarsh100 wrote:Awesome! I wonder why it was not mentioned in the release notes?
I was working from a long list of changes and that change wasn't on my list; it's definitely in the v1.0.4 update though.
There was one additional change that didn't make it into the release notes: Mod Wheel now always sends CC1, even if panel is set to output NRPN instead of CC messages. Formerly, if the panel was sending NRPN, the Mod Wheel would also send in NRPN format. This meant that when the panel was in NRPN mode, the mod wheel stopped controlling external gear. Now you can use NRPN mode (which is useful in Local Off mode because all panel controls send an NRPN, where some don't have a CC assigned to them) and still use the mod wheel to control plugins or other synth modules.
