Ah there's a relief! Now I don't feel like THAT GUY so much...it may be hard to believe but I actually forgot about the noise fix when I was writing the release notes
v1.0.4
Re: v1.0.4
Re: v1.0.4
i don't think your question was trollish in any way. it was a valid question. when i first saw that list, i asked myself the same thing...mmarsh100 wrote:Uhg. I didn't mean that post to be a trollbartleby wrote:too embarrassing, perhaps?mmarsh100 wrote:I wonder why it was not mentioned in the release notes?I was curious and posted w/o thinking...
sorry
Re: v1.0.4
Hello Rufus,
As gencomproducts mentionded, it´s still there in this new software-version, but not so insistent as before. I can live with that ...
Regards
Heiko
I don´t think that you need "magic ears" for hearing it. I would think you need to visit an ear specialist.Rufus the Dog wrote:You have magic ears
Regards
Heiko
My current Moogs: Sub 37
My former Moogs: Minimoog Model D, heavily selfmodified Prodigy, Satellite, Etherwave Theremin
Re: v1.0.4
The buzz, although reduced, is still present. Are there any plans to completely get rid of it or is that not possible because of the hardware? Just wondering.
Re: v1.0.4
OSC 1 suddenly only could sweep between triangle and PWM where triangle took up the range 0-8 of the knob and the rest was a little PWM. No saw, no square, just triangle and PWM.
Saved the patch and the knob was working again when I switched the patch back.
- Rufus the Dog
Re: v1.0.4
Will do at the weekendgencomprodukts wrote:gencomprodukts wrote:Rufus, try one of my "Model D" soft lead sounds and let me know if you do hear something :Rufus the Dog wrote:You have magic ears
R.
https://www.dropbox.com/s/yjr63cdac16n4 ... d.syx?dl=0
I do (check with the last octave of the keyboard)
R.
Re: v1.0.4
My 37 just froze when yanking the USB cable. Turned it off then on and it worked again.
Re: v1.0.4
Rufus the Dog wrote:Will do at the weekendgencomprodukts wrote:gencomprodukts wrote:Rufus, try one of my "Model D" soft lead sounds and let me know if you do hear something :Rufus the Dog wrote:You have magic ears
R.
R.
MOOG Memorymoog+, Sub 37, CP251, ROLAND SH-1, SH-2, SH-7, SH101, Juno 60, SVC350, TR808, SCI Prophet 5 Rev.3.1, KORG Mono/poly, KR55, OBERHEIM SEM, WALDORF Microwave 1, DSI Prophet 08 Desktop PE, BOSS DR-55, BassBot TT303, AKAI MPC1000 JJOS2XL.
- Rufus the Dog
Re: v1.0.4
hmmmm - having problems send the sysex file to the Sub37. Tried both C6 and SysEx Librarian… midi light blinked but Buffer remained with previous contents - any idea what I am doing wrong. I was abe to dump the buffer back to my Mac?gencomprodukts wrote:Rufus the Dog wrote:Will do at the weekendgencomprodukts wrote:gencomprodukts wrote:Rufus, try one of my "Model D" soft lead sounds and let me know if you do hear something :Rufus the Dog wrote:You have magic ears
R.
R.
R.
Re: v1.0.4
[/quote]
R.[/quote]
Oops, unfortunately i can't help you out
R.[/quote]
Re: v1.0.4
I don't think you're doing anything wrong... the deal is... this sysex is not a "buffer sound" It was exported using "cur preset" which tags the sysex file with the original bank/patch location, and if that sysex file is sent to another unit it loads to the same bank/patch location. I think you will find this one in bank 1, patch 14.Rufus the Dog wrote: hmmmm - having problems send the sysex file to the Sub37. Tried both C6 and SysEx Librarian… midi light blinked but Buffer remained with previous contents - any idea what I am doing wrong. I was abe to dump the buffer back to my Mac?
R.
gencomprodukts: you might prefer to use "buffer snd" to output single presets in future, as it's slightly better for sharing.
cheers,
- Rufus the Dog
Re: v1.0.4
Thanks Amos - got it now and will start to play
R.
R.
Re: v1.0.4
Thanks Amos, i didn't know thatAmos wrote:I don't think you're doing anything wrong... the deal is... this sysex is not a "buffer sound" It was exported using "cur preset" which tags the sysex file with the original bank/patch location, and if that sysex file is sent to another unit it loads to the same bank/patch location. I think you will find this one in bank 1, patch 14.Rufus the Dog wrote: hmmmm - having problems send the sysex file to the Sub37. Tried both C6 and SysEx Librarian… midi light blinked but Buffer remained with previous contents - any idea what I am doing wrong. I was abe to dump the buffer back to my Mac?
R.
cheers,
- Rufus the Dog
Re: v1.0.4
Ok, thanks to the tip from Amos played with gen's sysex…. recorded several seconds at 44,100 but turned off Osc2 so the slow beat with Osc1 didn't confuse.
FFT shows 80Hz some 60dB down from fundamental note (plus a bit of mains hum, 50Hz in the UK) and I cannot hear it but that could just be the monitoring headphones I am using and/or my lack of magic ears
This is several seconds of a single note using 'Latch On' for your listening pleasure.
https://dl.dropboxusercontent.com/u/48045856/OSc1.wav
R.
R.
Re: v1.0.4
Im new to this forum and not finding v1.0.4 of the OS...where can one download it?
