Building on the other ideas presented and a few of my own, here is the flow diagram I came up with (BIG thanks to Bryan B for creating the pretty mock-up and for helping with posting images!!):
Written explanation:
6 knobs - Drive, Bias, Sensitivity, Gate Source, Mix, & Output.
8 sliders - Hold1, Attack, Hold2, Decay, Hold3, Release, Amount & Offset.
1 (green) rocker switch - Invert & Normal.
Bypass foot switch
Tap Tempo / Trigger foot switch
2 Audio inputs
2 Audio stereo outputs
Gate CV / Audio In
Envelope CV In
Sensitivity CV In
Mix CV In
Gate CV Out
Envelope Generator CV Out
MIDI input
LEDs for Drive, Bias, Gate Trigger / Tempo
AUDIO
Two Audio inputs “Audio (L)” & “AUX Audio (R)”. AUX is switched, when un-used “Audio (L)” is supplied here. One can input either a single audio source, or a stereo source, or two separate sources entirely. The input level of both channels can be adjusted at the Drive & Bias controls. The Audio signal is then sent to channel specific VCAs, a mixer and finally stereo output jacks. Mix controls the blend between the input signal and the effected signal. Output controls the overall level of the final sound.
VCA
The VCA can be controlled by an internal Envelope Generator or an externally supplied CV. A rocker switch is provided to “Invert” the control voltage for the right channel only. The result provides either panning / cross fading effects or volume envelope effects to both output channels. When only the mono output is used with two inputs the effect is an automated cross-fading mix. When one input and one output are used, the result is an additive tremolo effect that sounds similar to a Bias tremolo.
ENVELOPE GENERATOR
The Envelope Generator contains six stages: Hold1, Attack, Hold2, Decay, Hold3 and Release.
HOLD1 stage is time based. (1ms - 10s)
ATTACK is time based (1ms - 10s) and changes the voltage from 0v to the Hold2 voltage.
HOLD2 is peak based (+/-5V bi-polar voltage output) where the peak relates to the level of the VCA. In Invert mode with stereo outs, this controls the L / R stereo position, in Normal mode, this is the volume of the sources. Pressing and holding the TAP foot switch allows the user to set the length of time that the hold cycle is engaged for using the slider from 1ms to 10s.
DECAY is time based. (1ms - 10s) and changes the voltage from the Hold2 voltage to the Hold3 voltage.
HOLD3 is peak based (+/-5V bi-polar voltage output) where the peak relates to the level of the VCA. In Invert mode with stereo outs, this controls the L / R stereo position, in Normal mode, this is the volume of the sources. Pressing and holding the TAP foot switch allows the user to set the length of time that the hold cycle is engaged for using the slider from 0ms to infinite. At the maximum setting this hold stage acts as a sustain stage.
RELEASE is time based (1ms - 10s) and changes the voltage from the Hold3 voltage to 0v.
The envelope voltage is available at the CV out.
GATE / TRIGGER
The Envelope Generator is triggered by a Gate source. The source of the gate is selected using the Gate source knob, seven options are present. The unit contains an internal Gate generator that can be applied to either audio source, or the control voltage input - these sources have a sensitivity applied to them, meaning you can control when the gate is triggered by the source audio level. Each of these sources can trigger in two modes - Single, or Mulit. Single forces a full cycle of the EG based on Gate length. Multi allows a re-trigger to occur at any point in the cycle. Similar options are provided for the CV input, where the sensitivity can be applied to a third audio signal - the signal is not present at any output. The final source is a looping EG that is sync’d to the tap tempo, Gate CV pulse, or MIDI clock source. At any time, the Tap / Trigger foot switch can be used to trigger the gate, however it will behave corresponding to the Single / Mult. / Loop setting.
PATTERN
Two additional parameters - amount and offset have been set as sliders. Amount controls the amount of the envelope that is sent to the VCA. Offset is a bipolar control that can be used in conjunction with the Hold1. As offset is moved away from the centre position, the envelope sent to VCA2 is shifted by the amount specified. The limits are set as a ratio of the overall envelope. 1:1 produces an envelope that has all stages synchronized between VCAs. 1:16 would produce VCA1 envelope and 16 looped VCA2 envelopes. At the flip side, 16:1 would produce 16 VCA1 envelopes while one VCA2 is produced. The result is a rhythmical pattern in stereo, complex tremolos, or complex mixing of audio.
MIDI
Under the hood MIDI options would allow for adjustment of the stereo phase option. This would allow the user control of added width & balance within the unit, increasing the stereo field produced.
MIDI in would allow clock sync, and control of all parameters. This is where creativity can really be applied, as I had so many ideas for this part that it would take a while to type. Ultimately the architecture of the rest of the pedal would help define this. Things like syncing the EG stages to MIDI clock, as opposed to just the gate would be great.
CONCLUSION
I believe this idea should appeal to all users from DJs, synth lovers, guitar players and studio engineers. As usual, Moog sound quality to warm your tone!!
