Messenger - Total Fail - Midi Clocking, DAW Integration & Reliability
Attention = I hope that Moog figures the Messenger out. It has a lot of issues. Even with the latest firmware as of 1/25/26 firmware version v1.1, the midi sync is so unbelievably unstable in Ableton. There is also latency pressing first note which was supposed to be fixed as of this firmware. Using Midi FX in Ableton to trigger an ARP or really any Midi Effect causes a lot of problems. I tested a whole bunch of different ways to connect the Messenger - USB, MIDI, MIDI Thru, MIDI interface, etc. I tried with my S61 Mk3, Midi templates, Novation SL Mk3–and it’s just the Messenger that is the problem. The Midi is so so buggy. Maybe I got a lemon, but I’m pretty confident its this design and buggy firmware / OS.
I have ZERO issues with my other gear involved in the test - Novation Peak, Sequential Take 5, Moog Slim Phatty and many others. I even went back to previous firmware versions. Unfortunately the Messenger and this release was not tested vigorously in a studio or live setting where you have multiple Midi devices all needing to clock and have tight sync. The Messenger is just plain sloppy. Moog needs to get it together. And the Editor? Pffhh. It needs a major rethink.
The sad part is it sounds awesome on its own. I wanted this to work so badly. But it just cannot stay if it is not reliable. I’ll stick with Arturia running through my Apollo.
Indeed, the arp should be synced to the midi ā€˜play’ command, and should preferably also have the option to be note synced. The sequencer is synced with the midi start command and is note synced if I remember correctly, but the ā€˜sequencer on’ status cannot be saved to the patch, so it’s unuseable when sequenced from another device in combination with program changes. I also cannot use the Messenger for the very purpose I bought it for. But it sounds good on it’s own… Waiting for Moog to have this resolved!
Yes the ARP/SEQ issue drove me insane. Who makes a synth that behaves this way? How would anyone perform live or In a studio setting like this?? Not to mention the lag missing the first note timing.
Since there’s no moderator interaction on this forum, I’m not sure if the Moog development team is reading this forum. I’ve made a ticket with InMusic today to address these midi sync issues. I hope there will be a follow up on this from Moog.
I have the same problems. The sync of the arp is not stable to use it live. I hope for a fix of the firmware.
Just tried again today to get the midi going with Messenger. A incredibly simple setup in Ableton. One external instrument and audio. It simply cannot maintain consistent tight clocking. It will work for a bit and then lose clock. 1 midi cable directly to the unit and no USB connected. It’s just so unreliable. Anyone reading this should save themselves and stick with plugins.
My sequential synths and Novation Peak will run solid. I let Ableton run some arps and came back 10 min later and it was still tight as ever. My Moog Slim Phatty is so much more reliable than the Messenger. Wow. So bummed this is the state of Moog now.
Thanks for raising this @sloanlogic i thought that i was going insane :shaking_face: So glad to see that im not the only one, aswell as dissapointed as i agree that on it’s on it’s great. The pain for me is that this was my first HW synth purchase, been using VSTs for years and thought now’s the time and it’s a moog. Now i’m a little sad but hope they can just patch it in the near future.
Will keep an eye on this thread for any progress.
If there are any relevant answers from InMusic/Moog support, I’ll keep you guys updated in this thread.
Thx @CorneelD . Lemme know what Moog says. Unfortunately I returned the Messenger. If you haven’t checked out synapse audio’s Proxima or HZ the Legend– they are pretty amazing. Software synths sure, but through my LA2A, API, Curve Bender EQ and Distressor– I’d say its does the job.
And obviously all the other Moog soft synths. Just a shame the Messenger is so buggy. It could be the little secret weapon that could.
Indeed, I also have HZ The Legend. Haven’t used it that much but it’s a powerfull vst for sure! I bought the Messenger mainly to be sequenced with the Digitakt. The Messenger running on it’s own arp or sequencer while receiving the transposing notes form de Digitakt. For now, that’s not possible in any practical way. I’ll hang on to it and hope they’ll come with a fix… which can’t be that complicated in my opinion. It looks more like an oversight.
I have the same issues. It usually locks up and needs to be restarted when receiving alot of midi.
This haven’t been fixed for a year and I am beginning to wonder if they put a too weak cpu inside since it is still an issue.
I’ve been in contact with Moog support, and the issues were forwarded to Moog development team. Some of the issues were already reported by others. However, they will not keep me up to date regarding which changes are currently under development, which is fair. We will have to keep an eye on future firmware releases. But I have to say I’m happy so far with the response I received from InMusic and Moog. Not selling the Messenger for now…
Picked up a Messenger a few days ago and experiencing some MIDI issues as well. I couldn’t articulate the Arp issue, but it sounds like the same thing people are having above.
My issue is the ā€œlocking up when receiving a lot of MIDIā€. In my experience, it may have been due to me sending it PC messages as well. A few times there have been issues. No deal breakers, but without a screen to verify information, it is a little frustrating at times.
I was about to purchase a Messenger - would have been my first Moog ever, and first hardware synth in about 10 years, but then came across this thread while doing my research and for me, it’s a deal breaker. I was hoping to use the sequencer and arpeggio in my limited studio set up, and also to use the Messenger as a master control keyboard, but these issues have changed my mind. I think #i probably go for a Korg Multi/Poly instead- shame. I do hope Moog resolve all these midi issues for you guys who have already made the purchase, and maybe I will be a future purchase - Best of luck to you all
The problem with YouTube reviews is they don’t show synths being used in real life studio scenarios. Does it do well with clocking? How does it do when Midi chained? How is the synth when you need to use the arp or sequencer inside a DAW? Unless you just perform with it on an island with nothing else, these reviews are pointless only to get a sense for what it sounds like and the potential for its usefulness in a studio. If none of this works, there’s no point in buying one or having to wait until Moog decides to ā€œfixā€ it with firmware. @NkyD71 You’d be better off getting a Slim Phatty if you want that Moog sound with a simple design and reliability with midi or Subsequent 37 that has an editor you can use inside a DAW.
this infuriates me. I have yet to find a single tutorial video with a midi cable plugged in while using other keyboards.
I have to say that Behringer software quality is top notch compared to Moog. Behringer next time for me.
My Messenger arrived yesterday & was very excited for its arrival. Firmware update went fine & had a tinker with the presets as you do with a new synth. very impressed by the sound. Then I decided to set it up for its long term intended use & hook it up to Ableton Live like my other hardware synths. my excitement very quickly turned into frustration & annoyance.
Yeah, it’s pretty un-usable when hooked up to Live. I tried connecting the following ways on macOS
USB - USB - same as my ASM Hydrasynth which works flawlessly
DIN - DIN via my Focusrite 8i6 interface - this is my connection for my JP-8000 and works with no issues at all.
DIN - DIN via my long since supported Midiman Midisport 2x2 running a 3rd party driver which is the way I connect a 30 year old analogue Waldorf pulse with no issues whatsoever
With the messenger connected via any of these methods its just a mess. things get out of time pretty quickly & the filter cutoff might as well be a 2 stage switch as there is no change to sound when you turn it, it only changes sound when you stop turning it. the Synth also demonstrates other odd behaviour as soon as you hit play in Live.
I will give it a week or so & see if anything improves or I can find a workaround but it’s probably going to end up being sent back to Amazon as it’s just not fit for purpose. What concerns me is the fact the synth has been out for nearly 10 months and it still has these issues which are quite big IMHO.
Found a partial fix atleast. It seems to be the ā€œlocal offā€ that is broken. If I have the keyboard set at ā€œlocal onā€ and don’t have ableton forwarding the midi info back to the messenger things seems to work atleast better… Did not investigate further, was in in a middle of a busy session, but this seemed to work in that moment atleast.
