Messenger - Total Fail - Midi Clocking, DAW Integration & Reliability
I don’t understand why I’m having the opposite problem of everyone else.
Just for a bit of context, I got a very early model. The store literally got it when it was first released and never took it out of the shipping box it came in.
When I booted it up, it was missing almost all of the presets. Only bank 1 had any. Apparently there’s supposed to be a lot more? I read online that the early releases had this problem. I don’t really care about that; it just confirms I have an early model.
But here’s what I came here to talk about: I’m having time syncing issues, but they’re the OPPOSITE of what everyone describes. The arpeggiator and timing works fine; it syncs right up to Ableton. Yes it’s delayed, but anything coming into my interface is delayed. I can easily crop it out, no big deal.
The one thing I cannot get to work no matter what is the LFO 1 Rate sync. No matter where I turn that knob, it is on some time interval that makes no sense. It’s not even that the ends of the waveform of the LFO don’t line up with a beat division (though that’s a problem too, I suppose): I cannot even get a division I search for. If I want a square wave that does quarter notes, NO position gives me it; they are all either too fast or too slow. I have tapped that knob with the lightest of taps when it is too slow, and it becomes too fast.
I’ve updated firmware, no help.
The one CONFIG setting I was hoping would help I can’t even tough because something seems wrong with it. Either the manual is wrong or it’s defective. The MIDI Clock Setting (Page 3 Option 3): the manual says “PGM 1 = Respect Start/Stop (lit) Ignore Start/Stop (unlit)“. Well, PGM 1 AND 2 are lit! This makes me think it’s a completely different setting, so I don’t even know what I’m editing.
EDIT: I actually tested it and I cann’t even get LFO 1 to sync to the Messenger’s OWN clock. No matter what I do, LFO 1 is at a rate that is NOT synced with any tempo, no matter what division.
The frustrating thing is not being able to find any examples of anyone describing an issue with the LFO 1 rate syncing; it’s everything else syncing that people have issues with. Not to mention I can’t find anyone else with the setting issue.
Before I go through the whole process, here, does anyone else have the specific LFO issue?
I dont recall if I had this issue with LFO Rate Sync. Because I couldn’t get midi to clock properly in any reliable way I would assume that anything the Messenger is trying to “Sync” would probably be unstable as well, including LFO Rate. Sorry you’re having trouble.
I just posted about this. Exact same thing. My model came with barely any presets too. I then updated the firmware and that gave me the presets.
The one Config setting you were hoping to fix is exactly where I landed and I found the exact same issue - PGM 1 and 2 are both lit. I have no idea what I am editing here either. I am trying to get the arp and sequencer to start and stop with my main sequencer and play in time. Everything else seems to be working fine. Maybe it doesnt work that way and you have to just press the play button manually to get the arp to start? I don’t know, I can’t figure this out.
I fixed it. This is what worked for me. There is a forced firmware update mode you have to use. Hopefully it stays this way. Everything is now in sync.
1. Force‑reinstall the latest firmware
Follow this exactly:
  1. Download the latest Messenger firmware from the Messenger Downloadspage.
  2. Connect Messenger to your computer via USB‑C directly (no hub, try a good cable).
  3. Power off Messenger.
  4. Hold PITCH and AMP (bottom‑left buttons) and keep holding them while powering on – this forces firmware update mode.
  5. Run the firmware updater app (macOS .dmg or Windows .exe) and follow the on‑screen steps.
  6. If it says “device not responding” after sending, unplug/re‑plug USB and run it again as prompted.
Then retest: DIN MIDI IN set to DIN, Octatrack sending clock, change BPM and see if Messenger follows.
Just to follow up here. There are zero issues with the Moog Subsequent 37. I have no problems at all with sync using either DIN, USB or both with the Sub37. The editor and plugin work beautifully. Some serious attention is needed for the Messenger.
Don’t think it’s sloppy just difficult to program
What are the steps to use it as an external clock to a slave
Ouch.
I found the 1.1 update to be much more reliable when on installation I used the replace option rather than the repair option.
After owning Messenger for 6 months I finally found the solution for Tempo Syncing
When the official moog youtube channel started the MPC Sample+moog Messenger series
I asked them in the comments to please do a back and forth sync demonstration between them because I own both devices but no luck so I had to dig deep on random tutorials
So because I’m completely new to synths & working with external gear I had no idea what PPQN was now that I know most DAWs default PPQN (Pulse Per Quarter Note) is 24 you should set your Messenger to 24 PPQN (you can only do this inside the Global settings Editor)
PPQN is basically a pulse signal pulsating at a rate which it communicates to external gear
And that’s it set your PPQN to 24 and you’ll get the tightest & most reliable sync between Ableton & Messenger but in my case only 5 pin MIDI connection works flawlessly (I’m on Windows 10) for some reason the USB C is only perfect for using the Messenger as a MIDI controller (I believe only the 1,2,3,4..16 buttons & settings, bank, patch etc those buttons can’t be MIDI mapped but the 29 knobs even the Volume knob can be mapped & control a VST effect or a VSTi synth this is huge in my opinion & many miss this feature)
Small things to be aware of:
So you try my method Ableton is running on your machine Messenger is connected you press ARP & Play on the Messenger & hold a few notes to ARPeggiate on and you are confused why there’s no sound at all…that’s because Messenger is waiting for Ableton to send the MIDI clock signal so first you press Play on the whole session (not just a MIDI Clip) and Messenger will sync perfectly to Ableton’s tempo you can even vary the tempo inside Ableton while you are holding your ARP and it won’t go out of sync because your PPQN is at 24 (tight)
And the solution to SYNC with MPC Sample is:
Set the MPC Sample to 24 PPQN of course set the Messenger to the same value
Same problem again: you start your SEQ or ARP on the Messenger and there’s no sound from the Messenger…yes press Play on the MPC Sample to get the Clock signal
In this case I’m using the official KORG SQ CV Cable which goes into the MPC Sample’s SYNC Out and goes into Messenger’s Clock In (which is a CV connection)
That’s it both SEQ or ARP works & syncs perfectly at 24 PPQN this way
Hi guys, it’s 27th July 2026 and I’ve just purchased a Moog Messenger and have exactly same sync issues with my DAW Abelton. Have latest firmware and tried on both usb & midi din but always same issue…Moog drops in a second late and out of time… I have several pieces of Behringer synths and drum machines…no midi sync issues at all… Very dissappointing from such a world renowned company as Moog. Looking over social media…so many other Moog Messenger users having same problem… Cannot understand why Moog have not addressed this serious issue? I bought this Moog for synth bass and it won’t sync… sadly that’s not much use to me. Tried the previous post’s offered solution of PPQN 24…did’nt work for me. Any update from anyone??
I found something interesting about the Messenger’s MIDI “coding/values”
I think we can’t access these things with the official manual or guides:
Tons of value on this site
I had the same problem with the only factory presets I had was Bank 1, 1-6. When I typed in this problem and sent it to the InMusic help AI it shoot back with a solution with the speed of lightning. That told me a lot of people got Messengers with the same problem. And the thing is I just got this 8/14/26. As soon as the real life BS gives me a break I will test the MIDI. I hope I didn’t piss my money away. It does sound great as a stand alone.
I’m in 100% agreement with this post and well done for your composure….I’d’ve wanted to shoot the corporate suit wearing money grabbing twats for doing such a crap job….. if only this was China….. YES!!! ….it’s that bloody annoying, frustrating, disappointing and enraging….
The midi is crap!
As for the ‘editor’ they’re taking the piss quite frankly.
But then…Moog isn’t Moog anymore…. The same as Steinway Pianos…. They’ve been a hedge fund company for at least 20 years…. They make them out of mdf now !!!
I agree about the LFO1 syncing….it’s as if this synth was put together by pen pushing accountants and not engineers …..and don’t start me on the midi…or lack of….shit!!
I feel totally ripped off with my Messenger…. Money thieving cunts!!!
I was mad, now I’m just disappointed, I totally agreewith the sentiment of being ripped off.
But I had zero understanding at that time.
I’ve inquired about trading my messemger in, and I was told to expect a slight bit over a third of what I paid. It’snow a trinket of naivety and unless I get can get better than half my money back, it will eventually get recycled.
