Recently, I have been comparing my voyager with minimoog samples, minimoog patches in spectrasonics' trilogy and creamware's minimax (because I don't have a model d) and was coming to the conclusion that the voyager just isn't as punchy as its old dad. The envelopes don't seem to be able to produce a sufficiently plucky result and are a bit clicky as well. Also, there is a bit less top end in the voyager's oscillators and these factors seemed to conspire to produce a a slight flabbiness of tone.
But I couldn't believe the voyager wasn't capable of more so I started experimenting with my modular and pretty soon I was getting much more favourable results, particularly when I used another envelope together with the voyager's.
About an hour ago, it struck me: the voyager's filter envelope doesn't open the filter enough. This means that in order to completely open the filter, the filter cutoff has to be quite high. So when the filter shuts down, there are still a lot of higher frequencies hanging about. And it is this that is contributing to the voyager's paunchiness.
Even without a modular at hand, though, you can utilise this technique by routing the filter output of the vx351 into the filter input on the back of the voyager and voila!, much punchier envelopes.
Try it, I think you'll like it
suth.
