maeghan
Post
by maeghan » Mon Aug 16, 2010 10:11 pm
I've got my voyager plugged in to my MOTU MIDI express 128. No MIDI messages are being sent. I'm running Snow Leopard and i've got everything cabled correctly in Audio Midi Setup. I've tried different cables and no luck. I've double & triple checked to see if Local Control was turned off, and it was on. I don't know what to do. I don't usually have it connected via MIDI, I record straight up audio. I just want to be able to back my sounds.
Any help would be greatly appreciated.
Thanks so much ~ maeghan
(aka - pulsewidthmod)
http://www.pulsewidthmod.com
monokit
Post
by monokit » Tue Aug 17, 2010 4:28 pm
Does the Motu shows that it is receiving on a channel?
maeghan
Post
by maeghan » Tue Aug 17, 2010 4:41 pm
The MOTU shows no sign of receiving any MIDI message from the voyager. I took the same cables, plugged into the same port and plugged them into another synth and MIDI messages passed through.
maeghan
Post
by maeghan » Tue Aug 17, 2010 4:42 pm
As for the MIDI channel, the voyager is set to send MIDI on all channels and receive on all channels.
monokit
Post
by monokit » Tue Aug 17, 2010 5:08 pm
Hm, if you´ve tried everything what the manual says, i would try to get in contact with the Moog support and ask for help. Maybe something is broken.
-edit- One more thing you could try...plug your other synth via midi to your voyager, pick on both synth channel 1 and see if you can play the voyager via the other synth and vice versa.
maeghan
Post
by maeghan » Tue Aug 17, 2010 5:32 pm
Thanks for the suggestion, I'll try that. Sadly though, I think something is broken.
RL
Post
by RL » Tue Aug 17, 2010 6:23 pm
I have a stupid question: is the MIDI output on on MASTER page 1.2?
Have fun,
Rudi
http://www.moogmusic.de
maeghan
Post
by maeghan » Tue Aug 17, 2010 8:38 pm
Rudi, thank you for your stupid question. MIDI out was set to OFF!
(now I feel stupid
