mp201 channels triggering other channels
This is the place to share tips, tricks and questions about Moog's controller products; the MP-201 Multi-Pedal and the EP-2. There are a world of applications for these expression enhancers. Explore...
RAH
Post by RAH » Sun Mar 14, 2010 9:35 am
hey forum..
is there a way to trigger channels from triggering other channels. ie. triggering channel 3 (controlling the filter cutoff for instance) and at the same time turning on channel 2 (controlling a different parameter, say modulation amount..). So if you planned on using them both always together, you wouldn't have to stomp twice to turn this combination on and then twice again when you wanted to turn them off...
any ideas..sorry if this is an obvious answer, but it isn't immediately clear to me with the manual and a quick search of the forum.
thanks.
