Patch for ELP's "From the Beginning" for the Voyag
mattgalletly
Post by mattgalletly » Thu Feb 04, 2010 11:54 pm
Is there a patch out there for "From the Beginning"? Did I overlook it in the patchbook? Do I need a Fooger or a Controler for this one?
mattgalletly
From the Beginning patch for the OS
Post by mattgalletly » Fri Feb 05, 2010 12:00 am
Is there a patch for "From the Beginning" for the Voyager OS?
GregAE
Re: From the Beginning patch for the OS
Post by GregAE » Fri Feb 05, 2010 8:46 am
mattgalletly wrote:Is there a patch for "From the Beginning" for the Voyager OS?
Matt -
I assume you are referring to the synth solo that Emo plays at the end of the song? As you may have discovered, it's not in the OS Patch Book. I've been trying to nail that sound for years with no luck on a Voyager Performer. A few folks here on the forums have offered simplistic versions of the patch, but none of these has captured that elusive low modulation effect that makes that patch so special.
If I ever figure out the secret to making it work on a Voyager, I'll post it on KT.
- Greg
LWG
Re: thread topic
Post by LWG » Fri Feb 05, 2010 9:21 am
Hello,
You can find a version here:
http://launch.groups.yahoo.com/group/mm ... G%20patch/
Its posted in the Voyager OS patch memorizer application format.
The source Vger it was patched on was a Signature which did not have filter glide.
Because the OS and later model Vgers were updated with
the filter glide function, a given patch that uses glide will sound a bit different between the two machines.
You may want to make an adjustment in the filter based on this.
I had hoped hoped that the filter glide function would be made
switchable as it would allow complete portability between patches
programmed on older and newer Vger editions.
Regards,
Lawrence
SorryEntertainer
Post by SorryEntertainer » Fri Feb 05, 2010 9:50 am
I'm about to purchase an OS. A quick question to you guys, if I may. Does the patch book come with each Voyager Old School? Thanks in advance.
mayidunk
Post by mayidunk » Fri Feb 05, 2010 10:52 am
I always loved that patch! I believe that in order to recreate it you will need one oscillator emitting a saw or "edgy" triangle wave, and one self-oscillating LP filter (or sine wave source...), whose outputs are both routed through an additional LP filter.
I'm gonna play with this today, maybe I'll get lucky! :D
mattgalletly
Post by mattgalletly » Fri Feb 05, 2010 1:48 pm
SorryEntertainer wrote:I'm about to purchase an OS. A quick question to you guys, if I may. Does the patch book come with each Voyager Old School? Thanks in advance.
Yes. It does.
mayidunk
Post by mayidunk » Fri Feb 05, 2010 3:15 pm
Here are settings that I believe get close to Emo's patch for that riff.
Sync and FM are off. Osc 3 is set to normal range, keyboard following (not free running.) No modulation routings.
Settings are as follows:
Glide = ON
Glide Rate = 4.5 (value)
Osc 1 - Octave = 2' - Wave = 1.5 (value)
Osc 2 - Octave = 32' - Wave = 0.75 (value)
Osc 3 = Osc 2 settings
Mixer osc 1 = 3
Mixer Osc 2 = 6
Mixer Osc 3 = 6
Filter cutoff = 1K (value)
Spacing = 0 (value) (ie, straight up)
Resonance = 3 (value)
KB Cont. Amt. = 0 (value)
Filter Mode set to Dual Low Pass
Filter Envelope: A = 12:00 (position) - D = 12:15 (position, just a little past 12:00) - S = 3 (value) - R = 1 Sec. (value) - Amt to filter = 4 (value)
Amp Envelope: A = 10 (value) - D = 10 (value) - S = 7 (value) - R = 1:00 (position)
Add just a little bit of reverb to give the notes a slight ring. Play the riff kind of staccatto, to trigger the envelopes for each key hit.
I have the Behringer SE-200 Spectrum Enhancer, and the MF-101 LP Filter in my 'fooger chain, so the resulting sound has good bite and a bit more low-end reinforcement. You can compensate for this by adjusting the OSC 1 wave just a tiny bit more towards a sawtooth to add bite, and by increasing the Osc 2&3 mixer levels just a bit to increase the bass. The keyboard is set to the null transposition setting. Starting the riff at middle E on the keyboard sounds about right, though it may not be exactly in the right key. Before you start the riff, "prime" the portamento by hitting a high note first, so you get that characteristic swoop down to the first note.
I hope this provides a good starting off point. Please let me know how close I got, as I did it from how I remember the sound of the patch.
Bob
SorryEntertainer
Post by SorryEntertainer » Fri Feb 05, 2010 3:45 pm
Yes. It does.
Thanks a lot. :) Good news.
Portamental
Post by Portamental » Fri Feb 05, 2010 10:00 pm
SorryEntertainer wrote:Does the patch book come with each Voyager Old School?
Yes, and that's the first thing I checked at the store, asking the salesman to open the box and see if it's there, before coughing the dough. And to this day, i dont' think I have used it even once. Maybe I should look it up see what I am missing.
mattgalletly
Post by mattgalletly » Sat Feb 06, 2010 12:03 am
mayidunk wrote:Here are settings that I believe get close to Emo's patch for that riff.
Glide = ON
Mixer osc 1 = 3
Mixer Osc 2 = 6
Mixer Osc 3 = 6
Bob
Yup that sounds pretty darn close, but I had to raise the octives one setting on all three oscillators to get it to sound just right :D
Thanx
mayidunk
Post by mayidunk » Sat Feb 06, 2010 11:06 am
mattgalletly wrote:
mayidunk wrote:Here are settings that I believe get close to Emo's patch for that riff...
Thanx
Thanks! I guess that's not too bad for an old man who hasn't heard that song in a few years! :wink:
Marzzz
Post by Marzzz » Sat Feb 06, 2010 12:14 pm
The original MiniMoog Model D manual had written presets which included several by Keith Emerson. One of them was listed as "Trilogy" but it was actually the patch for the ending solo from "From the Beginning." Back in the day when I had an original MiniMoog, I played it and it completely nailed that sound. A quick search online found an example, you can use it to work up the same patch on the Voyager:
Spumoni
Re: Patch for ELP's "From the Beginning" for the Voyag
Post by Spumoni » Tue Nov 29, 2011 1:55 am
Let me start by saying that I'm a total novice when it comes to making sounds, even though I've been puttering for the past 20 plus years doing it. I just upgraded from a Phatty to a Minimoog, and today is my first day with it. I bookmarked this page a month ago because I was anxious to hear this patch, and I had a difficult time trying to figure out what knobs the notes were referring to. Then I found a patch on the Moog that was called "from the beginning", and it wasn't even close! I made a patch on my Phatty using only two oscillators and it sounded much better.
I plan on locking myself in the house and not letting myself out until it's done. I will do better than just "come close".
yesman
Post by yesman » Tue Nov 29, 2011 7:39 pm
Hey just to add my bit
I happened to hear the song recently and was thinking about how to create that sound. I think the above patches come close but, I was thinking that the lower pitched VCO was modulating the VCF that the high pitched VCO was feeding. I remember it as a tone like when you whistle and hum at the same time, you get those additional sidebands. This is just my take on it, I'll have to listen again and see what I hear.
