pot value on the standard moog expression pedal
This is the place to share tips, tricks and questions about Moog's controller products; the MP-201 Multi-Pedal and the EP-2. There are a world of applications for these expression enhancers. Explore...
zerstorte zelle
Post by zerstorte zelle » Mon Jan 11, 2010 6:32 pm
Just wondering what the correct pot value would be to affect the full range on the moogerfoogers? something like the frequency on the ring mod has a huge sweep.
any thoughts?
Last edited by zerstorte zelle on Tue Jan 12, 2010 4:00 pm, edited 1 time in total.
Klopfgeist
Post by Klopfgeist » Tue Jan 12, 2010 1:07 am
Which pot? If you are controlling something with an expression pedal (not the MP-201 Multi-Pedal), the pot whose function the voltage from the pedal is being sent to should be set at the minimum value you want (i.e. if you want the lowest frequency to be 1k and go up from there, set the pot at 1k). An expression pedal can send voltage that can control the parameter higher than the pot's range.
So this thing only plays one note?
http://soundcloud.com/unarius
http://www.youtube.com/user/plague1715
zerstorte zelle
Post by zerstorte zelle » Tue Jan 12, 2010 2:15 pm
sorry, poorly phrased.
I'm in the process of building some cv control interfaces and I was wondering what the pot values were in the typical expression pedals.
thanks for the reply and keep 'em coming.
zz
Voltor07
Post by Voltor07 » Tue Jan 12, 2010 4:55 pm
The main expression pot is a 50k Linear Taper pot. I use 50 and 100k linear taper pots for my homemade device(s). :wink:
