Has anyone experienced this problem with any of the MFs:
When I power it up the two LEDs (for bypass and level) blink simultaneously and that's it. In other words I can't switch from bypass to normal mode and there seems to be no signal at all running through the unit. It just happened from one day to the next. Am rather stumped...
Fortunately still under warranty
thx
john
MF-107 LEDs blink together -- no signal
- Portamental
I had the same condition when I first powered up my Midi-Murf, no bypass, flashing leds, the unit just not working. I was stumped too. This particular time (and I never do this) I had the MF-105 perched on top of heavy loudspeakers. I'll never know if that was the culprit or not, the second time, the unit was moved to it's intended location and has been performing flawlessly from then on.
