My mod wheel causes logic to solo the track?!
Anyone have any idea why my mod wheel would casue logic to solo the MIDI track?
I have similar problem with my LP + Logic setup. Some CC# cause logic to do different things like muting the track, starting recording. Logic is just accepting some midi msgs as his own controls.
Most of those problems can be solved by goin into Project -> Midi settings and setting up midi input filter for CC, Program Change and stuff (except for pitchbend and notes) if you want to record, but then you will probably won't be able to record modulation. Also try recording on a different MIDI channel then 1.
Despite all those things some problems will happen, if you find a flawless solution please let me know.
