NEW Buchla modular system produced...
Wow this looks incredable.
http://buchla.com/200e/index.html
Will it work with the Voyager? It must be able too...
$20,000
I would still like to have one.
$20,000
For all those in Europe interested in the Buchla 200e, rlmusic.co.uk has just been apointed Exclusive UK and European dealer. There will be a fully populated 200e at RL's offices in Reading shortly.
http://www.rlmusic.co.uk
A very interesting machine, more complex and chaotic in it's sound creation then a moog . . . perhaps we'll see a new modular from Bob sometime soon?
Mal
Mal
Boeing
If you compare a Buchla 200e to an all-in-one polysynth then yes the price seems to be very expensive but remember this is a very high end modular system with feature not found on ANY OTHER SYSTEM.
You only have to weigh up some of the features to understand where your money goes . . just think about a modular system where all patch cord positions could be saved and recalled with the preset (This is posible with the 210e and 225e modules). This is a real "audio lab in a box" . . . set it up and the thing will compose and play all by itself!
What do you think a 35 year old Moog Modular would go for now? The Buchla comes in cheaper (only just though).
mal
mal
Just to be specific, it can only store knob settings and switches, not the actual routings of patch cords. You're going to have to use your digital camera for thismee3d wrote: just think about a modular system where all patch cord positions could be saved and recalled with the preset (This is posible with the 210e and 225e modules).
In all, the mid priced system looks the best deal. Plus I read that Buchla hinted at the posibility of future modules being developed for the 200e.
I just wish there were some samples up or a freakin manual.
monadsJust to be specific, it can only store knob settings and switches, not the actual routings of patch cords. You're going to have to use your digital camera for this
That's not true . . . if you use the 210e and you permantly wire it as a matrix switcher, so a patch cord goes from each I/O array to the relevant other modules I/O then the 225e preset manager will remember the routing per preset . . . with enough 210e's in the system it should be possible to control all the routing of the complete system meaning you'll never have to re-patch it.
Moog had a system almost like this in the early days (a manual version) where it was possible to seperate a sound out through a "programmer" module . . Keith Emerson uses 6 of these modules in his monster moog, you can then switch from one set of patches to another via these 6 modules (so 6 sounds) . . . trouble is you have to have enough modules in the system to make up multiple sounds . . . so you would have to have 12 VCO's, 12 enevelope generators, 6 filters etc, etc to make up 6 simple 2 VCO lead sounds. On Keiths system you can see different coloured patch cords for each preset sound.
Mal
Correct. But then the faq goes on to say the "210e Router can store and recall interconnection data for a small number of patches"? This left me confused. You're right, you'd probably need additional 210e's because on the CV section 5 outputs and 8 inputs is limited. At $1,250 a pop is it really worth it? I already find the 225e 50 preset manager a setback. Granted it's amazing an option is even available but I already thought the Voyager was harsh for only allowing 128 recallable presets. Start adding more 210e's and we're getting up there and that's not including patch cords or sales tax if you live in Cali.mee3d wrote: That's not true . . . if you use the 210e and you permantly wire it as a matrix switcher, so a patch cord goes from each I/O array to the relevant other modules I/O then the 225e preset manager will remember the routing per preset . . . with enough 210e's in the system it should be possible to control all the routing of the complete system meaning you'll never have to re-patch it.Mal
Who else makes the equivalent of the 210e and 255e for modular synths? No one. With that kind of brilliant design, the price is worth it.
Look at the 249e Dual Arbitrary Function Generator - a two channel embedded version of the old 248 MARF. It is a high powered sequencer that includes time transients between stages, so it be used to generate complex envelopes, complex sequences, it can be used as a quantizer, and it has voltage control of stages. That last feature is rare but powerful - you drive a ramp input and it cycles between the stages; crank the ramp frequency high enough to get the stage cycling in the audio range and you have a VCO with the stages defining the waveshape.
This is a module with multiple uses - Don's design philosophy for years. That's worth the money he is asking for that module.
And the 259e Complex Oscillator - one serious VCO. Don takes nonlinear electronics to the max to provide controls for timbre that you won't find on any other VCO. Basically it is a combination LFO/VCO with FM and waveshape modulation - but with waveshape in the form of two timbre controls so you can get the basic VCO waveforms and modulate them to get complex waveforms. I have had flight time with a Buchla Music Easel which had a Complex Oscillator, and trust me when I say you don't need a filter with one of these.
Here's another seemingly plain module - the 281e quad EG. Ah, but you can cascade each EG to get complex envelopes. Don provides pulse outputs at the final decay stage so you can trigger other events like gating sequencers and stuff. The EGs can be looped to get complex LFO waveshapes. There is also a quadrature mode which can be used in LFO mode - quadrature LFO waves are very handy for modulation sources on VCO and VCFs when processing stereo signals.
Don's expertise is designing modules with multiple uses to them. And you thought "dual use" exports to foreign countries were dangerous
Buchla and Associates must have price in mind otherwise they wouldn't offer three suggested configurations. Just offer the bid daddy 20k unit and that's it! You either can afford it or not. The fact that it's Buchla, and his designs are esoteric, just makes you want to pick one up and learn/experiment. All I really wanted was Alan Pearlman to return to the game and update his 2600
