pedal assignation
elliot.t
pedal assignation
Post by elliot.t » Thu Nov 05, 2009 7:52 pm
Hello,
I want to use an expression pedal, but it is always assign to the volume level, and I want to use it for amount filter. I don't find the solution in edit mode, please help me.
Elliot
latigid on
Post by latigid on » Thu Nov 05, 2009 8:09 pm
Do you know how to program modulation via the mod busses?
Post by EricK » Fri Nov 06, 2009 12:03 am
What do you want to use an expression pedal to achieve?
elliot.t
Post by elliot.t » Fri Nov 06, 2009 11:10 am
In fact I use my voyager rme on stage and I play others keyboards to. So I would like to change the amount-filter with a cv pedal. When I plug it into my moog the default is volume control and I want to change that.
And I ask myself if it's possible to have different parameter between the preset (edit) or if it's only possible for the master.
