This is the place to share tips, tricks and questions about Moog's controller products; the MP-201 Multi-Pedal and the EP-2. There are a world of applications for these expression enhancers. Explore...
teddykjam
Post
by teddykjam » Fri Oct 30, 2009 12:11 am
I tried to backup my presets after the 2.0 update on an intel macbook pro 10.5.8 and Sysex librarian won't see incoming midi from the MP201. it worked fine before the update. I saved my presets before updating the MP-201 from firmaware 1.01, and I WAS able to load them back into the MP201, so the MP-201 sees the midi from Sysex librarian.
I have all the midi stuff on, USB, DIN etc... should I have them merging? All my merging is off.
Teddy
http://teddyjam.com
Prime NL
Post
by Prime NL » Fri Oct 30, 2009 5:11 am
Did you also select the MP-201 in the top menu of Sysex Librarian ?
Sometimes it will jump to the default midi equipment setting.
teddykjam
Post
by teddykjam » Fri Oct 30, 2009 8:13 am
Prime NL wrote:Did you also select the MP-201 in the top menu of Sysex Librarian ?
yes, and might I add that I also restarted about 10 times just to see....
Teddy
http://teddyjam.com
