Fun technique I discovered on my LP today
Everything Phatty.
Sir Nose
Post by Sir Nose » Fri Sep 25, 2009 12:40 pm
With an open gate switching through presets can produce some really neat sounds. I've been playing around just using the knob but a sequencer is gonna be nicer. When switching to a new preset with the gate open it goes directly to the sustain part of the envelopes. With the correct setup of differnt presets you can set up artificial mutli stage envelopes, neat digi step effects, and some brutal basses.
CTRLSHFT
Re: Fun technique I discovered on my LP today
Post by CTRLSHFT » Fri Sep 25, 2009 1:21 pm
Sir Nose wrote:With an open gate switching through presets can produce some really neat sounds. I've been playing around just using the knob but a sequencer is gonna be nicer. When switching to a new preset with the gate open it goes directly to the sustain part of the envelopes. With the correct setup of differnt presets you can set up artificial mutli stage envelopes, neat digi step effects, and some brutal basses.
i'm totally gonna try playing with this, sounds like a blast!
www.ctrlshft.com
Sir Nose
Post by Sir Nose » Mon Feb 08, 2010 9:29 am
Randomly stumbled upon another one of these over the weekend. Crazy rubbery bouncing sound, switching from one preset to another while holding down the key. It sounded different with just an open gate compared to hitting a key and then switch the preset with the key held down, probably velocity->filter with the keystroke. The sound after the switch was made is way different than just playing one after another. I have not tried it via midi CC, I hope it is still as smooth as using the value knob. That would make it easier to try different combinations and could produce some exotic effects from a sequencer.
Post by EricK » Mon Feb 08, 2010 9:33 am
This would be nice on the Voyager, except that when you change the presets you have to hit the switch again.
Interesting find.
christophe.bruynseels1
gate?
Post by christophe.bruynseels1 » Mon Feb 08, 2010 9:45 am
sorry but what do you mean by gate open?
Sir Nose
Post by Sir Nose » Mon Feb 08, 2010 10:16 am
Plug a cable connected to nothing or a jack without a cable into the gate in jack. The OSC will drone. You can press a key to change the pitch and make sure the sustain in the amp section is up.
Portamental
Post by Portamental » Wed Feb 10, 2010 7:35 pm
hummm gotta try that... on the double!!!!
miamigroove
Post by miamigroove » Fri Feb 26, 2010 8:46 pm
yes, but be careful. all the blinking lights can cause seizures LOL :lol:
