vx 351 info please
dell shaw
vx 351 info please
Post by dell shaw » Sun Jun 21, 2009 5:31 pm
hello well i have just been reading the forum witch said you need at least 20 patch leads 4 the vx 351 at the moment ime waiting on more comeing there was none in the box ? eny way at the moe i have tried a few basic patches from the manule . and joined KnobTweak, i would like more info on just wot i can do with it i was think about expanding but should i get used to the vx 351 first cheers evey one and happy solstice ,,,,,, :D
bunnyman
Post by bunnyman » Mon Jun 22, 2009 9:33 am
The only cable that should come with the VX is the DB 25 cable to connect it to your Voyager. So, you're on your own getting those extra 20 (at least!) 1/4" cables! As far as patching, a fun one is to take the Mod Wheel CV > LFO rate in. LFO Square > Env Gate in. Turn the Env Gate switch to on/external. Voila, variable rate repeating. I use this with a Buchla Percussion sounding patch, and it's a lot of fun!
-a bunny
Post by EricK » Wed Jun 24, 2009 4:53 pm
It all depends on wht other CV gear you have. THe Vx351 is a great tool for things like controlling other CV gear with the touchpad or with keyboard voltages (like getting extra oscs out of the freqbox or external filter sweeping via kbd)
Its really great for giving you alot of extra sources for voltages for new destinations, including the voyagers cv inputs.
You should invest in TRS patch cords rather than just the mono patch cables because trying to run something like the touchpad out to the mix knob of a ring mod and the kbd voltage into the Osc input of the ringmod will cause the signals to ground out and you won't get your function like you intended to.
dell shaw
thanks for the post
Post by dell shaw » Wed Jun 24, 2009 10:43 pm
sound job i have started making patches i got 20 leads and started experimenting and stooped worrying ,, :-)
Subtronik
Post by Subtronik » Wed Jun 24, 2009 11:11 pm
Good, sounds like you're on the right track. No need to worry when you have a Voyager anyway.
dell shaw
a lil trick to do with your cv vx 351 expander
Post by dell shaw » Thu Jun 25, 2009 1:17 am
bunnyman wrote:The only cable that should come with the VX is the DB 25 cable to connect it to your Voyager. So, you're on your own getting those extra 20 (at least!) 1/4" cables! As far as patching, a fun one is to take the Mod Wheel CV > LFO rate in. LFO Square > Env Gate in. Turn the Env Gate switch to on/external. Voila, variable rate repeating. I use this with a Buchla Percussion sounding patch, and it's a lot of fun!
-a bunny
ha har i sussed thank the lord , sorry for getting giddy i lol
i was scratching my head at first and then it all came clear Sue per
smashing , if eny one as eny more please post thank you for the
tip all the best dell ,,, keep tuning the nobs,,,,, "Everybody knows that's what aliens sound like -Bob Moog .
