New Owner.
Mooger_Fracker
New Owner.
Post by Mooger_Fracker » Thu Apr 23, 2009 12:40 pm
Hey,
I have an Old School (love it) and a Kenton Pro Solo. Can somebody please tell me the what the settings on the kenton need to be as well as the i/o on the OS.
Thanks,
Baz
acorkos
Post by acorkos » Thu Apr 23, 2009 12:54 pm
are you running a midi sequencer into the kenton to control the OS?
connect CV out on the kenton into the OS PITCH jack (red nut) and the GATE out from the kenton into the ENV GATE jack (blue nut). On the OS front panel, switch the red ENV. GATE switch to ON/EXTERNAL. You should be in business. Hit different keyboard keys to change the key of your sequence.
You have some additional control options with the kenton's AUX jack....it looks like you should be able to control filter sweeps, L/R panning, volume, waveform from your sequencer (via the red nut jacks on the OS), as well as from the kenton's onboard LFO.
Mooger_Fracker
Post by Mooger_Fracker » Thu Apr 23, 2009 3:40 pm
Thanks very much for your help. It worked perfect.
