For those of you with a Moog guitar
Have you tried running a Sample and Hold CV signal into the CV-in while controlling the Harmonic Blend? What does it sound like?
Bryan
Bryan
Err . . . no. "Sample and hold" is a type of control voltage. It samples a noise source at a periodic interval and holds that voltage over the interval. The result is a random voltage that changes periodically. I'm really curious to know how quickly the Moog guitar can respond to CV control and how it sounds when physically controlling the strings.Theremint wrote:When I get my Moog guitar, I will try it and let you know or send you a .wav clip. I'm assuming when you say "sample" that would be playing a few licks on the guitar right?
Does that makes sense?
Bryan
Theremint I called Sweetwater Fri and it should be anyday now.Moog finished this production run,so now it's a matter of sorting thru the orders and shippin em out.
Bryan,I don't have anything I can use for the sample hold,my effects are mostly stompers.I am planning on getting some floogers,but that's in the future.I'm also planning on getting the new theremin,maybe after I pay for the Taurus pedals
You can never have too many musical instruments.
THe Cp251 and the guitar would go good together.
Give you smoothe/stepped S&H, LFOs, and the abillity to send complex waveforms into the guitar, not to mention being able to send the audio signal to 3 different destinations.
Youd also be able to send noise into the filter as well as lag processing any waveforms into the guitar.
Man too bad I can't crap 6 grand.
Thanks for checking it out. I hope to get my hands on one of these guitars to try soon.georgeludwig wrote:Bryan,
I tried it using ann MP-201 to gennerate the sample-annd-hold control voltage. As I suspected, the effect isn't very interesting. It takes a fairly long time for changes in the harmonic blend control to affect the sound, so the effect is quite subtle.
CV control
Now that I have the Moog guitar, and so far the Mooger fooger and the analog Delay, I was wondering what I should add to the system, as apart from using a TC electronics Gsystem for some things, I would like to have a totally Moog based system.
What I was wondering is does anybody have any ideas about, what would be the most effective add on, one of the Control Voltage generators or one of the sound modifiers. any idea's.
This is truly and amazing instrument, I wonder what they will do for version 2 and if mine will be upgradeable.
Analog is real, digital is unreal.
