Voyager RME Volume Control
Juanv101
Post by Juanv101 » Wed Dec 03, 2008 10:17 am
I have been using my new RME for two weeks and yesterday I saw that it sends sound signal even when the volume control is set to 0.
Is this something normal? It happens both in Headphones vol and master vol
Regards
Juan
Post by EricK » Wed Dec 03, 2008 12:21 pm
Are you talking about the strange noises that occue when you turn the unit on and it is booting up? Ive notived that when it is cycling through the buttons Panel Master Edit...it will send all sorts of LOUD crazyness through the headphones and the Outputs regardless of headphone or master volume.
This I believe is just a normal occurance of analogue oscillators, as the theremin does the same thing. I think it has something to do with the power activating the oscillators and the VCA at the same time so some stuff is leaked out before the VCA gets to proper operating temperature and closes.
Does this answer your question?
Juanv101
Post by Juanv101 » Wed Dec 03, 2008 4:01 pm
Erick
no, it's true that it makes that noises.
I meant that even when the sound level of the headhone or master volume is set to "0" , the voyager is still sending sound to the amplifier.
I had not appreciate it when I use it connected to my computer, but yesterday I connected it to the amplifier, and I saw that even with 0 volume the amplifier received sound from the moog
Regaeds
Juan
Post by EricK » Thu Dec 04, 2008 12:38 am
Now it could be that you are using an amp that boosts the signal so much that you are hearing that....but in theory, the VCA is supposed to be closed.
You might want to email the tech support guys on that one....pm Amos on this forum or email them on their homepage.
