Mixing CV within MP-201
Am I correct in saying that the various channels of CV cannot be mixed within the MP-201? Wouldn't it be cool to have internal mix so that you could combine the four independent CV signals internally and then spit the sum/difference/offset/inverted combination of those from one CV output?
Bryan
Bryan
Re: Mixing CV within MP-201
Yes. The MP-201 has no ability to mix individual CVs internally. Your suggestion is a very cool idea. I'm sure that Amos, Cyril or Steve could tell us if it's possible to implement (there's also the issue of combining up to four output signals, each of which can be +/-5V (that's potentially +/- 20V!), but I'm sure there are ways to deal with that).Bryan T wrote:Am I correct in saying that the various channels of CV cannot be mixed within the MP-201? Wouldn't it be cool to have internal mix so that you could combine the four independent CV signals internally and then spit the sum/difference/offset/inverted combination of those from one CV output?
Bryan
As for external CV mixing with the Multi-Pedal, I use a simple ART 4-channel passive mixer:
Since the ART has no Master knob to control the overall output, I route the ART's Mixer Out to an Attenuator on the CP-251 before routing the signal to a CV input, and keep the Attenuator set low initially (best to be safe here).
As you can imagine, being able to combine up to four LFOs of different waveforms and different rates can result in some pretty interesting CVs. In my experience, I usually run out of patch cords before I run out of ideas...
Sure, but I'm hoping to eliminate the need for a CP-251 for live use. Presets would be nice!GregAE wrote:Possible? Maybe...Bryan T wrote:Also, is a smoothed version of the Sample & Hold CV possible? That would be nice!
Of course, you can always smooth the S&H using the Lag Processor in the CP-251. Note also that the individual Rise and Fall knobs give you an extra bit of control here.
Bryan
As it is right now, the MP-201 has a limiter that keeps voltages between -5 and 5. You can see that when using the offset on the LFOs.GregAE wrote:Yes. The MP-201 has no ability to mix individual CVs internally. Your suggestion is a very cool idea. I'm sure that Amos, Cyril or Steve could tell us if it's possible to implement (there's also the issue of combining up to four output signals, each of which can be +/-5V (that's potentially +/- 20V!), but I'm sure there are ways to deal with that).
That's a simple solution, but it does lose the preset capability that I crave.As for external CV mixing with the Multi-Pedal, I use a simple ART 4-channel passive mixer:
Thanks,
Bryan
simple additive mixing of LFOs might be possible within the MP201.
You would get a lot of clipping against the maximum and minimum levels unless the original LFO amounts are kept low (1/n where n = number of LFOs to be mixed).
I will add this to the list of feature suggestions, and we'll see what happens. In the meanwhile, I think that you can get all of the combinations you describe by using the CV mixer on the CP-251.
If you save all the LFO settings as a preset and use the same mixer settings on the CP251, it's almost a preset...
Amos
Amos
