Maybe not exactly what you're looking for but ever since I started exploring CV (with my Voyager/RingMod/VX-351/Frostwave Resonator I've looked for ways to expand upon it as well.
A couple nice things I found were my Korg Poly 61 can take a trigger input for the arpeggiator and my DSI MEK can not only process incoming audio but also 2 CV signals that can then be used to alter just about any param you can think of. Really great synth since it contains a 4-track analog-style arpeggiator and has both analog (2) and digital (2 more) oscillators and some crazy filters, etc.
Once again, not CV, but I've been using my Voyager Mix In to route all sorts of stuff through my setup. I route audio into the Voyager and then from there it goes through various CV-controlled effects, etc.
Although it is probably overkill I can easily run the Nord Electro through the Voyager, then through the effects listed above plus a fuzz and delay, then into the DSI MEK then into a Virus TI and finally out to tape. You can get some really wild sounding stuff running through the Moog filter, the MS20 filter on the Frostwave, the Curtis filter on the DSI MEK and then through the Virus TI! Wierd Wild Stuff!
Sorry to go sorta off-topic here...but half of this signal path is analog
Minimoog Voyager Performer Edition + LP Stage II + Sub37 + Model D reissue + CP-251 + VX-351
