I need this to be addressed:
I and propably many other Logic users are having difficulties as LPs main volume controls Main volume in Logic and Oscillator 2 frequency knob controls Pan and Oscillator 1 Waveform knob controls Logic's main output Mute. Of course these CCs can be filtered off in Logic or transformed into different CCs (from incoming midi stream but then I loose the midi control in LP). I believe those CCs (7, 9, 10) are fixed in Logic.
Is anyone else using Logic and how do you get by with this? Transformer object perhaps?
OT: Anyone else having problems with Logic and LP
Hey detune -- I use Logic Expresss, but have been having the same problems. I haven't been able to find a straight up answer on how to go about solving the problem, but the solution does seem to lie in using transformer objects to change the offending incoming MIDI CC's on the LP's channel, and then doing the same on the way out of Logic.
The way in seems pretty straightforward in the Environment -- not sure on the latter however -- of course, Logic Express doesn't have transformer objects so I haven't been able to experiment around. Hopefully somebody here will have solved this problem as I'm going to be upgrading soon (can't wait forever for Logic 8!!)
