Midi in problem , , , only reads overlaped notes
inducer
Post by inducer » Thu Feb 01, 2007 12:14 pm
This is a new problem that just sprouted up. No matter what the sorce (virus - cubase - groove box) my Voyager will only trigger a incoming midi note if the note before overlaps it. Example, midi out to Voyager midi in, I have to hold a note down with my left hand the entire time the right hand is playing. All notes from the right hand are played if they do not overlap. The first or held note is never played by the Moog. Even with gaps between note from the right hand the Moog will never slide up or down to this (held) note. This is true no matter what patch the Voyager is set to.
From the Moog (Mac) Librarian, in edit mode, the Voyager receaves all the knob tweeks and on/off messages. Patches are sent and changed, But still the notes will not trigger from the vertual keyboard in the librarian. And yes, the midi ON is on in the master settings of the Voyager.
Outgoing midi is fine. Racording into Cubase, everything shows up (presure - mod wheel - notes - ect). Play back only the second of the over lapped notes will sound. Non overlapped notes, will not trigger the Voyager.
I installed the newest OS again with no change. I find nothing in the Master Mode that seems to fix this problem. Am I missing something? My Moog gear is the heart of my studio and my inspiration. So when it is not working, , , I'm kind of freaked out. REALLY, I'm not kidding.
Thanks for any and all help.
inducer
Post by inducer » Thu Feb 01, 2007 1:19 pm
Problem fixed !
THANK YOU to the tech guys at Moog.
