De Nada. No Metronome. No Thru Thru.
- My Muse is receiving Midi In - I am sending a play command and clock from PC and the sequencer happily starts.
The downstream device....nothing.
Same cable plugged into any other device that has thru ports - the downstream device works fine.
Does Muse have voltage on its thru port? Is it the correct voltage?
I think I recall somewhere seeing ~3.3v vs ~5v on outs being a factor on if this device would work...I wonder if that's what's happening here?
