First of all, Messenger don't receive any aftertouch from other controllers (keyboards or Push 3).
Then, with right midi I/O settings and local control off, it is impossible to record a filter cutoff movement in Ableton, because Ableton receive a lot of CC numbers and not only the filter. Sound change in a uncontrol way.
Sometimes program change or very slow to apply.
Perhaps i don't understand how to use it with Ableton, perhaps it is a lot different that my other synths, including Moog ones.
Is anyone is able to use it with Ableton Live, in Midi in/out way to record movements on the pots ? How ?
Midi issues
Midi issues
Re: Midi issues
I could figure out the cause of the problem. It is not a midi issue but a USB issue. Without any usb cable, everything works ok. But with a USB cable connected to my Macmini M4, Messenger change sounds and sucks midi CC in different ways (even if USB not connected on settings !).
So need a firmware update to use USB like i actually can use the synth with midi DIN.
Re: Midi issues
It seems to be solved by the new firmware 1.08
