Arp issue with MIDI
MOOG MESSENGER - All thinkgs Messenger! The next-generation analog synthesizer from Moog.
hollarob
Arp issue with MIDI
Post by hollarob » Fri Jul 11, 2025 5:27 pm
When wanting to use the Arp in a DAW, I get very strange behaviour. Playing on the Messenger -> DAW -> Messenger, the Synth is just playing the pattern once and then constantly playing the last note. This also happens when the track is armed and a MIDI clip is playing from the DAW -> Messenger.
When the track is unarmed, it is working, but the clock has a huge delay, it seems.
I have Local and the sequencer sending notes off, use firmware 1.0.7, and tried a factory reset.
Does anyone have the same issue?
Synthetique01
Re: Arp issue with MIDI
Post by Synthetique01 » Mon Jul 14, 2025 1:23 pm
Same thing occurring in Ableton live using midi din, using the arpegiator. When you stop the transport in live, the sequence either continues, or there's a hung note. Messenger then locks up and has to be rebooted. All settings checked, latest update installed and factory reset performed. Doesn't seem to occur when a single note is sent via the DAW, only when chords are sent to messenger.
Synthetique01
Post by Synthetique01 » Sat Aug 09, 2025 5:01 am
For me, appears fixed in 1.08.
