To Reproduce Scenario: I want to change to Bank 1 / Patch 8 during a live performance. I accidentally hit the Patch 7 button, so I quickly hit the Patch 8 button. Because Patch 7 had the PLAY button active for it's arpeggiator, now my Patch 8 is already playing it's saved sequence! Patch 7 would only make an ARP sound if played. And stops when not playing. So it was silent when I accidentally hit it. But if I change to any patch that has a sequence, it starts playing immediately.
Feature Request / Suggestion: Patches with Sequences default to the PLAY button BLINKING to show there's a sequence programmed. Then you need to tap it to start the sequence. And the light indicator would go solid.
Thoughts?
PLAY button behavior between patch changes (FIXED)
Live Setup:
Nord Stage 4, Moog Subsequent 37, Moog Messenger, Korg multi/poly, Hammond MSolo
Re: [Messenger] PLAY button behavior between patch changes
Addressed and fixed in v1.0.7
Live Setup:
After installing the new os there is still a problem with USB communication with the computer. The sound starts changing by itself without touching the instrument.
Same here, with ABleton it is a mess. Impossible to have something stable. I've tried every possible midi settings...Tomasz77 wrote: Sat Jun 07, 2025 3:02 pm After installing the new os there is still a problem with USB communication with the computer. The sound starts changing by itself without touching the instrument.
