I've had my Subsequent 37 for a couple months now, and I've really started to dive into it just recently. Now, I started a new project with a pluck preset, but when I automate the the osc1 wave type, the entire synth just glitches into a weird sustain kind of mode. Midi doesn't seem to correspond anymore either, only very vaguely, and it's like the synth maintains some kind of weird sustain level somehow and only responds to some of the ongoing midi notes. Other parameters respond without issues.
If I keep the automation clip in FL Studio at 0% (starting point, pulse wave), it doesn't have this effect. But as soon as I make it go up (so towards saw wave etc), it triggers the glitching mode.
This doesn't happen if I just change the parameter by using my manual mouse in the VST editor, nor does it happen if I operate the parameter through the onboard knobs. I've also tried to delete the automation and just automate it again, but the issue simply repeats that way.
I wanted to attach a video file showing it but the file size it too small.
Here's a reduced sized video file (10mb) showing it: https://www.dropbox.com/scl/fi/8li4ysqn ... g9ous&dl=0
Here's full quality: https://www.dropbox.com/scl/fi/x0oao2zf ... 7f15j&dl=0
What could be going on here and how do I fix it?
