Hi, I would need an advice on Subharmonicon and MIDI.
I can’t make it work with my Keystep, or more precisely, I can’t use the Keystep via MIDI to control anything but the clock. No sound is coming out of it, nor it controls the pitch… I already tried to upload the „new“ firmware, also checked the MIDI channels, everything should be set and still nothing.
Any help would be much appreciated! Thank you.
MIDI not working properly
Re: MIDI not working properly
There are two types of MIDI DIN to TRS adapters. Make sure you have the correct one.
