I came across this bug in the Matriarch yesterday, where when you set the arpegiator to be sent via midi, and you engage the hold button, it will keep the arpeggiation locked/latched, but it will also sustain the notes indefinitely. Making Usng the matriarch as an arp generator for third party synths, especially polyphonic ones, not possible.
To my surprise, i found that in the bottom of the release notes of Firmware 1.3 this bug was already mentioned and known!
Especially given the changes in the company, is it likely these bugs will ever be solved or adressed?
Matriarch: Known bugs In firmware 1.3 on release - will they ever be fixed?
Sub37,Minitaur,DSIProphet12,Cubase,AbltnLive,Reason,RMEfirefaceUCX +FocusriteOctopreMKIIDynamic, BabyfacePro,LaunchpadPro,AkaiMpk249,ZeroMkII,StrymonBigSky,ShermanFB2, Xbase09,TR808,PF500 Stagepiano, ElCapistan,HeddType07,Mics &Waay too many cables
Re: Matriarch: Known bugs In firmware 1.3 on release - will they ever be fixed?
In the Moog Matriarch Manual
p65.
Global Parameters. Group 2
Section 2.6. Sequence keyed restart
Bug
The sequencer operation is not affected by the changes made in Global Settings.
p65.
Bug
