Minitaur do not respond to editor controls
dsmonkarlive
Post by dsmonkarlive » Sun Jul 14, 2024 12:04 pm
I am using Macbook pro M2 and Ableton live 12. I have installed newest editor and minitaur firmware. Minitaur is set to midi in/out to channel 1. I have added external device in ableton and minitaur editor on the same channel. If i turn the knob on minitaur, it translates to editor ok as well as buttons. But if i change something on editor, the only thing translates to hardware is changing presets. Any knob or function change on editor is ignored by hardware. The wierd thing is also that midi light is lighting when im turning konbs on editor but no change to sound. Please help
capillotraktor
Re: Minitaur do not respond to editor controls
Post by capillotraktor » Thu Aug 22, 2024 1:36 am
Same here. No luck so far. It’s such a shame
Sangeet
Post by Sangeet » Thu Sep 05, 2024 2:19 am
I remember that I had numerous problems with the controller software. It was depending on operating systems, software versions from the Minitaur controller software and if I used USB for Midi or the oldschool Midi sockets :x
Meanwhile on my Sonoma Systems on both of my Macs - Intel and M2 with Logic Pro it's super reliable.
But in past it was so bad, that I didn't hope that it got sorted in the future, so depressed I was...
Did you guys tried with another DAW?
ummagumma
Post by ummagumma » Mon Jan 13, 2025 2:19 am
I just ran into this & figured it out:
You have to enable "echo DIN->USB" in the editor settings.
( In my case I'm using DIN MIDI to play the minitaur via Arturia keystep, and the standalone editor, not in a DAW. USB cable from Minitaur to Windows 7 PC controlling the editor )
