Taurus 3 sustain note?
mike112
Post by mike112 » Thu Feb 29, 2024 6:30 pm
I've had my Taurus 3 pedals for a while but just recently wanted to use the "pedal sustain" feature.....
Supposedly you make sure the "Latch" is turned to "ON" position and you hit a note, that note is supposed to remain on until you push the same note again....I just can't get it to work,....I'm sure I'm doing something wrong.....can anyone explain step by step how to do this? Thanks in advance for your help...
till
Re: Taurus 3 sustain note?
Post by till » Mon Mar 04, 2024 7:15 am
Which firmware version is used?
And you don't have MIDI or USB MIDI connected, right?
ReahaTaul
Post by ReahaTaul » Thu Mar 28, 2024 11:59 pm
The Taurus 3 latch can be a bit tricky at first. Here's the step-by-step for getting those sustained notes going:
Make sure your "Note Latch" parameter is set to "ON." You can usually do this with the cursor buttons and a value knob (check your manual for specifics).
Press and hold the desired note on the pedalboard.
Release the note. If latch is working, the note should keep sounding!
To stop the sustain, simply press the same note again.
If you're still not getting any love, double-check your manual for any other settings that might affect latch mode. Sometimes there can be a hidden menu or another button involved.
Hope this helps!
