latigid on wrote:I'm surprised you havent tried yourself! Anyways, I'm gonna try an experiment within the next few days with an oldschool telephone patchbay (one set of TRS sockets only). Basically, I'm going to loom individual TRS cables to each input and output of all my effects and a few synths.
Normalled, half-normalled and all that carry on won't matter; it's all hardwired. Inserting a jack will open two switches on the socket itself, so a closed switch (no jack inserted) will short the tip and sleeve to seperate grounds. So, careful wiring could effectively short two connections together, which would have the same effect as inserting a dummy plug...
Of course, you dont need to use the switches on every connection, just the ones requiring a dummy plug.
I'll let you know how I get on.
cool, thanks for the reply. yeah i'd love to try it myself, but before i go buy a ton of connectors and solder everything, i figured it might be a good idea to hit up the forums to see what other people might've experienced.
i can attest that TRS connector plugs like this:
won't work (i bought a bunch thinking this would solve the problem with me having to solder anything). i noticed if you pull it out halfway, and get it just right, the desired effect seems to work, but not for everything on the 104 and 105, and theres still a limitation in the available sweep range on both units. i'm not sure if by making all the channels isolated on the patchbay makes them no longer balanced or not, so theres another variable to consider (i'm guessing not though, cuz -+ stuff like triangle waves seem to modulate just fine.)
hmmm..
thanks again, i'll post too once i get a few TS connectors and try the jumper cable idea out with this patchbay.
