Voyager wave shape modulation
Quatschmacher
Post by Quatschmacher » Fri Mar 31, 2023 6:27 pm
Absolutely racking my brain but cannot figure out a way to modulate the wave shape of just a single oscillator via LFO (as opposed to all oscillators). Can this be done via any of the programmable destinations/pot mapping? I’d love to hear from anyone who has actually managed to do this.
ummagumma
Re: Voyager wave shape modulation
Post by ummagumma » Tue Apr 04, 2023 1:35 am
I just checked on mine & pot mapping gives you individual osc waves as destinations.
You might be able to use midi cc commands to do that too, from your DAW?
till
Post by till » Tue Apr 04, 2023 6:06 am
VCO 1 waveshape: CC # 9 (MSB) & CC # 41 (LSB)
VCO 2 waveshape: CC # 11 (MSB) & CC # 43 (LSB)
VCO 3 waveshape: CC # 13 (MSB) & CC # 45 (LSB)
If the normale MIDI precision of 7 bits (= 128 values) is good enough, just use the MSB Bytes (CCs # 9, 11, 13).
But modulating the individual VCO waveshapes via the Voyagers pot mapping is not possible. The LFO output is not a pot mapping source. But you may use an external LFO on the MOD 1 or MOD 2 socket and use this pot mapping:
SRC: MOD 1 (or 2)
Dest. OSC. 1 Wave (or the OSC. 2 or 3 waveshape)
Direction Normal (or inverted)
Amount 100% (or 50% or 25%)
You can use a source several times in the four pot mapping slots. But each destination may only be used one. If you set several pot mappings to one destination, only the first slot of this destination will work.
ummagumma
Post by ummagumma » Tue Apr 04, 2023 1:23 pm
Wow Till, that's great information, thanks for posting!
Too bad the LFO is not usable as a pot mapping source: I think I ran into this before: thinking the concept of "pot mapping" was "source mapping" but it's not.
if you have a VX351 breakout box you can get the LFO CV & patch it back to either mod source.
Some Moogerfooger pedals have LFO out, too
till
Post by till » Wed Apr 05, 2023 2:40 pm
The pot mapping was added later with a software update. It runs as a pure software. And as there is no way to get the analog output of the LFO into this digital chain (without the help of a VX-351 Voyager CV Expander), it is missed as a source.
The analog inputs like the MOD CV ins, the touch pad, the wheels and even the aftertouch (it is also an analog thing) are scanned like the pots of the front panel and transferred into the digital domain, as they are also used to send out MIDI data. So these are included.
ummagumma
Post by ummagumma » Thu Apr 06, 2023 10:27 pm
At some point I want to add CV ins for each osc wave shape. Too many other repair projects on the go though, and trying to write music too. No time..
Quatschmacher
Post by Quatschmacher » Wed Apr 12, 2023 7:38 am
Thanks for that info.
Is it possible to route the LFO CV out straight into the Mod1 or Mod2 jack to then be able to use that as a mod source directed to one of the wave shapes via pot mapping?
till
Post by till » Sun Apr 30, 2023 4:55 am
Quatschmacher wrote: Wed Apr 12, 2023 7:38 am Thanks for that info.
This should work.
